Question about Microsoft Xbox Console
The solution posted do not help cauz the unit is
I plug my xbox on 220 volts and its dead,i`ll open the unit and i found a burn mylar capacitor (color yellow) if i replace it with same value can it solve my problem
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
Try it if thats the only one burned than it should solve it
Posted on Jul 03, 2009
Can I get PNLV234 & PNLV233 AC INPUT 220 volt ???
though it is embossed as110 volts on the adapter casing,
it works in 220volts also.
Nov 03, 2013 | Lands Phones
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
WhAT HAPPENS IF I plug a 110 volt machine to a 220 outlet
Normally the plug connector would not fit, they are different. But for some reason, if you have one that takes 110 and you plug it into 220, there will be af ire. You will burn through the circuits immediately and short the entire thing out at every solder point. The real problem is the wattage. The watts are pushed with 220 volts of fource, which will fry your 110 setup.
Sep 27, 2012 | Olympus HPU-20 Cautery Unit
Turned it on for the first time this year. After a few minutes it would stop working but all the light indicators are still on. I made sure that the energy saver is off, that is is getting the full 220...
Yes, it could very well be a burned capacitor or a burned wire from over heating, Best advice is to unplug the unit and do not attempt to use it, until it is repaired.
To find an authorized service in your area, click on the link below.
http://hosted.where2getit.com/friedrich/search.html/
Hope this helped you. Have a good day.
May 31, 2011 | Friedrich Compact Programmable CP24N30 Air...
I Accisentally plugged My 110 Volt xbox 360 into a 220 volt outle
The reason for this is the power overwhelmed the circuit boards and burnt them out you may need to talk to someone up the Game shops or go to support.microsoft.com and see what other people think. even if microsoft tell you to DONT send it in for repair as it gets rattled in the post and rattling the console causes the Open Tray Error an extremley annoying error. hope this helps
Apr 08, 2010 | Microsoft Xbox 360 Console
Can i use an Xbox 360 bought in USA in India - given the voltage conversion required? would there be any seperate adaptor available for 220 volt usage in India
You can purchase a volt adapter (rather common in travel stores/airports) but over time the device's power-supply will wear out because of the frequency difference.
North America runs at 60hz
India runs at 50hz
Jun 30, 2009 | Microsoft Xbox 360 Console
The power supply of my pioner dvd was burn
Hi
check all semiconductor in the power board and look for a shorted and open parts! then replaced the defective parts.
Thanks!
Dec 05, 2008 | Televison & Video
Voltage
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Blows fuses
I found a post where someone replaced several capacitors with ones he described as titanium and a higher voltage like 100 v rating rather than 50 as oem. He states no more problems. I found this site while searching again. I also found a free download pdf repair manual from JBL - site defined as Harmon, and they show revised parts replacements for these caps - 100 volt. I just bought a used one and not hooked up as yet, but I plan to use slow blow fuses and possibly a little higher rating - not much though, and I believe there is a ceramic type - color solid white - that may withstand the apparant surge. Theres also a recent post somewhere for sale of the amplifer board... 64smi or something like that. Hope this helps. Ken
Jan 08, 2007 | JBL PSW-D112 Speaker
Microsoft Xbox Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
