Question about Kenmore Elite Oasis ST 6807 Dryer
Want to change the belt
Is there a trick to open the top washer? because i keep prying with a screw driver and it not coming up. i'm trying to get to the belt?
  • 39 Answers
Wath brand is it??? model???
Posted on Jul 03, 2009
Replace belt on fantom cyclone vacuum? the manual does not decribe replacing the roller belt - i can't get it open to expose the belt
On my 10-year-old model, the two screws securing the cover are under the two llight bulbs. Pry off the clear plastic covers, take out the bulbs and screws, and the cover lifts off.
Dec 01, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
Need to turn doors around , doors are opening to left side..need to open to right side
Good day,
Start from the top and work down.
Make sure all items are removed from both doors, and machine should be shut off.
1. Remove top bracket with the freezer door still shut.
With both hands, open freezer door about 1 foot, and lift off.
All thru this process keep track of all shims and washers and their location.
2. Remove center bracket holding main door and remove using the same process as with the freezer door.
3. Remove bracket from the bottom and reverse to the other side.
There will be a lot of press in buttons to be removed by prying them out with a small screw driver.
4. Reinstall in reverse order, making sure all shims and washers go back where they came from. As well, Tighten screws while making sure the door is in alignment at the same time.
5. Remove both door handles and reinstall. Some screws may be hidden by a cover that will have to be pried away first.
Nov 25, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
How do i get into the dryer to change the belt GE dde6500galwh
There are probably 2 screws on the back towards the top of the machine, on the left and right sides of the machine. unscrew those then take a flat-head screw driver and pry the front of the top of the machine off on each side there is a clip holding it...
there is also a access door in the back of the dryer somewhere, that will likely expose the motor and belt tensioner/spring. release tension and belt should come looser.
Nov 17, 2009 | GE Dryers
Loose cabinet
KInd of, just use a screw driver and put it under the loop. pry it up and they should pop free
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Lifting cover of dryer to fix loose baffle.
Usually their are two sheet metal screws to remove at the top rear of the washer lid/body,,,you must remove these,,,then remove any little brackets(some washers have little brackets which hold the top down) then you should be able to pry the top up with a screw driver,,,pry gently,,,if it will come at all,,it will come,,,but if it feels solid,,check for more points to remove screws.
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Aquarius Hotpoint.. keeps doing rewash after rewash.. door won't open when i switched the washer off its like its trying to either empty water, but making a noise when its trying it.. what wrong and can it...
Unplug First!!!!
You Can Pry The Top Off With A Big Flat Head Screw Driver Where The Seam Meets The Casing.
Then You Can Check The Belt Thats What Is Most Likely Your Problem. Take The Broken Belt To Your Local Auto Part Store And Tell Them you Want One That Size And Replace.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore Elite top load washer leaking
in the two front corners insert a putty knife and pry upward.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Amana lw8252w2 changing belt
there are 3 screws that hold the pump to the moter but sometimes it is rusted so you may need to pri it off
Nov 29, 2008 | Amana ALW480DA Top Load Washer
Dryer challenge
take off top to see if belt is ok
Mar 14, 2008 | Dryers
My vacum power head wont work
fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Elite Oasis ST 6807 Dryer Logo
57 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
