Not able to access the Internet through Dlink DIR-655
I'm not able to access the Internet through Dlink DIR-655 router. It gives error like not able to clear dns cache when i try to repair the Wireless Connection. i have tired to flush the dns using ipconfig/flushdns but it also gives the same error. When i have connected Modem to my Laptop then i'm able access the Internet. Plz Suggest how i can resolve this issue.
  • kailas_saraf Jul 03, 2009
    IP address is coming automatically when my computer is connected directly to Modem. IP Address is static while connecting to Wireless Router. I have two different NIC. One for LAN and other for Wireless.
SOURCE: VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Posted on Mar 17, 2009
cnavarro
  • 2460 Answers
SOURCE: need software for dlink dir 301 wireless router
You don't need no steenking software, it's in the box. You do need a country, because it's not on the U.S. website.
Look at your local IP address (ie from DOS type IPCONFIG). The gateway address is 192.168.0.1? Open up Internet Explorer and type that address into the address bar. It should open up a screen asking for a username and password. Here's where the manual might help (www.dlink.com) and do international.
Dlink routers tend to have the same instructions, so here's the help page from the website on a 714 router to establish WEP encryption.
http://support.dlink.com/faq/view.asp?prod_id=1075&question=DI-714P+
Hope this helps.
Carl
Posted on Apr 09, 2009
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
rtrahan
  • 741 Answers
SOURCE: Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Posted on May 03, 2009
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
D-link DIR 655 owner's Manual
Look on router ID plate for REVISION.
Owner Manual Links:
For DIR-655: http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655
For DIR-655 REV. B: http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655_revB
Thanks for choosing FixYa, If you find this helpful please vote and comment.
Oct 11, 2010 | Computers & Internet
I have a DLink Dir-655 router. It seems drop a lot.
try to configure your Internet connection settinngs and router cables
Jun 07, 2010 | Computers & Internet
Stack errors with dlink 655,,disconnect, and no problem to connect to Internet...Re establish 655 and all computers get Stack errors with IE
You might need to download a hotfix from Microsoft for this Stack Error... Try visiting the link below
http://support.microsoft.com/kb/895194
Hope it helps!
Mar 28, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a DIR 655 D Link router and I can't save changes.
Lots of possibilities, especially if the wireless device and your PC are older - the DIR 655 doesn't support wireless protocols 802.11 a and b, for example, only the newer g and n.
Start with getting the router software up to date (see http://us.dlink.com/products/connect/wireless-n-gigabit-router/ )
using an Ethernet link to a PC, and then debug the wireless access. The DNS message could be caused by the Windows wireless adapter config having a manual IP address vs the router being set for DHCP (dynamic) or vice versa.
Sep 10, 2017 | D-Link DIR-655 Wireless Router
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I need to secure my wireless internet
go into your wireless interent setting options.in your control panel.
Jun 15, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computers & Internet Logo
264 people viewed this question
David Payne
David Payne
