Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Low and idle speed engine dies
Hello fellas! I Have Honda xr 250 r 1995 and this problem.
The engine is running at idle speed (or vary low) when I throttle sharp (sudden) it dies. It seems like drown in gas, but I am not sure - especially when it still cold. The high revs are OK. Thanks!
  • stanstst Jul 03, 2009
    Sorry I guess I have chosen this mower by mistake!
  • 218 Answers
Hi..my name is Keith..and for some reason they put your question under lawn tractors..but i know motorcycles..and a Honda XR 250 is a motorcycle..so..with your problem..if your engine has run fine before..then you dont need to make any carb adjustments..but...if it hasnt then it could be the carb slide needs to be adjusted up or down to make it richer or leaner..but if it has ran properly..then i would suspect you need to install an accelerator pump kit in it..but you can check this by taking your air filter connection off and look in the back of the carb and have someone to operated the throttle quickly..and see if it sprays a stream of fuel into the throat of the carb(if it dont..you need a kit)...or the float is set at the incorrect height. or the float needle and seat needs replacing..but it is a carb problem...i hope this has helped..if not...write me back
Posted on Jul 04, 2009
2013 Honda Activa will not idle when warm
Hi, P and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Activa 2013 Engine Stalling
Honda Activa Engine idling stalling issue caused by faulty ring fitment...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 28, 2014 | Honda Activa Motorcycles
1999 Honda XR 400 R dies on an angle
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
XR400 starts and suddenly dies
Bike idles perfect but dies when given the slightest amount of throttle 93...
1996 2003 Honda XR400R Service Manual Moto Data Project
HONDA XR400R Owner Manual
May 19, 2014 | 1999 Honda XR 250 R
Want to verify reasons why 95 Honda Odyssee engine wants to stall and die at low speed
This is almost always caused by a dirty throttle valve and automatic idle speed control valve which is on the throttle body. Do the following to clean the system up.
To correct this problem Buy a can of throttle valve cleaner (it is made by CRC) from the local auto parts store, NEVER USE CARB CLEANING SPRAY, IT DESTROYS THE ANTI-STICK TEFLON COATING, spray it into the air intake through the throttle body of the engine until you have used about half the can, you will need to hold the idle up while you do this, it will try to stall, after this shut the engine down and disconnect the Negative (-) battery cable for 5 minutes. The intake is now clean, if you continue to have the idle speed control problems you may need to seek the help of a professional.
Feb 12, 2012 | Honda Odyssey Cars & Trucks
CAR RUNS GREAT, STARTED DIEING WHEN A/C WAS TURNED ON, NOW A FEW DAYS LATER IT DIES EVEN WITHOUT A/C ON, RUNS BUT WILL NOT IDLE
CHECK IDLE SPEED SHOULD BE 650 - 850 RPM. IF IDLE TOO LOW AC WILL PUT DRAG SLOW DOWN ENGINE CAUSING ENGINE TO STALL IF IDLE SPEED IS TOO LOW.
Sep 09, 2011 | 2000 Mitsubishi Eclipse
Honda XR 200 will not idle dies suddenly when cold
Hi, Success97601 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
XR200 won idle
XR200 Won Idle
XR200R service manual repair 2000 2002 XR200 Download Manuals Technical $15
http://mybikemanuals.com/honda/honda-xr-owners-manuals
Sep 03, 2017 | 2002 Honda XR 200
I have a91 xr250l w/ a pumper carb. Will not start.
It's a '91 model. When is the last time you had the carb cleaned out? Sounds like you've got a stopped up low speed jet. The hole in that jet is less than 0.020" in diameter. Doesn't take much to obstruct that. Do you run a fuel filter in your fuel line? I'd pull the carb and take the float bowl off. You'll see a large jet directly in the middle of the carb. Just off to the side, you should see another small jet. This is the low speed jet. Take it out and clean the jet using aerosol carb cleaner. Do not stick any wire or anything through the jet. You should be able to hold it up the the light see through it. Set you idle mixture screw at one turn off the bottom to begin with. Once you get the engine running and warmed up, adjust for highest smoothest idle speed. Good Luck
Nov 25, 2009 | 1991 Honda XR 250 R
Honda GX100 gas engine will not idle, it just dies. Runs OK at WOT
You will need to adjust the low speed idle screw. Make sure the spark plug is clean before adjusting.
Jul 13, 2009 | Honda Garden
Idle speed engine dies when throttled
It does sound like its getting to much fuel, or the lack of air. Air filter ok? If it is you might need to have a compression check done to see how the piston rings are.
Jul 03, 2009 | 2001 Honda XR 250 R
Idle is too low, car dies, engine runs fine
An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The car computer or ECM (electronic control module) receives information from various sensors and will output signals to adjust the IAC motor in or out to adjust engine idle speed by controlling engine idle air.
An IAC motor is highly susceptible to carbon and coking build up; if an IAC goes too long without cleaning it can cause stalling and poor idle quality. Some cars are designed with a large vacuum transfer hose that connects the intake manifold to the IAC (idle air control) motor. If a broken or dilapidated these vacuum lines can cause the engine to lose vacuum which will allow the engine to run rough and die.
Inspect all engine and accessory vacuum lines to look for missing, torn or dilapidated lines and replace as needed. To check the IAC motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the IAC should move in or out.
If the IAC motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the IAC motor is removed clean (use aerosol carburetor cleaner) the passages the IAC uses to control idle air speed.
Good luck and hope this helps
May 08, 2009 | Honda CR-V Cars & Trucks
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
331 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
