Question about Apex Digital AT2708 27" TV
No power tv plug in out currant is there but no power reaching the tv was check and was told that it needed the fly back 0304054037parts
    President:
  • 1,348 Answers
The flyback transformer generates all the voltage for a lot of circuits.they do go quite often.
Posted on Jul 03, 2009
Panasonic rear projection tv switches itself off has done for two days now, have been told it could be the power source needs to be replaced can you help
Try plugging it into a power plug . Also see if u have any sleep function or child lock system enabled in it . Check for any damages in power cord coming from the tv back . Also try connecting the tv via a voltage stabilizer unit . if the problem persists , then the fault will be with the power supply unit within the tv which is to be repaired by an authorized service personnel only .
Jun 01, 2011 | Televison & Video
T V was on when Power company switched off the breakers and all power to my house they were replacing the power ploe when they hadcompleted the job and switched the breakers back on my tv would not turn on...
hi
power suply blew up probably cause by over currant ,minor repair dough. You got to see your friendly repair guy and send the bill to power company
Oct 02, 2010 | RCA F36689 36" TV
My plasma tv want turn on
there could be the following reasons. If there is the red light on indicating the power reaching the TV then your power supply unit may be faulty. Open the back cover and look where the power cord goes and meet the components inside and it would also have a transformer like thing on it. This is the PSU module. If any of the capacitors is bulged or burst then that needs replacing with one of exactly the same specifications. Do that. Second is that there is no indication of the power reaching the TV. In that case check the plug and the wall socket and also the power on switch on the TV. Whatever is faulty should be replaced.
Nov 20, 2009 | Philips TV Tuner Video Capture PCI Card -...
Popping sound
if you had taken your tv ealier for repaire it had a switch problem, the sound you used to hear were arcs in a switch, but now it has a disconnection in side it. the problem is not very big. thanks
Jan 05, 2009 | Philips Magnavox 27MS343S 27" TV
My memorex mltd3222 will turn on for a split second and when the memorex logo comes up, the screen goes out
I don't have a permanent fix, but I do have a work around:
The problem appears to be some sort of "loose connection" associated with either the power plug or how the back of the TV is mounted to the front. Try the power plug first: we unplugged/plugged the plug from the back of the TV (i.e. not the wall) multiple times, jiggling it around a bit each time we plugged it in, and did so until we didn't hear the "pop/click" (i.e. the sound we've come to associate with the problem)... Voila! It started working again.
If that doesn't work, try removing all the screws from the entire back panel, moving the back panel up/off a bit (but completely removing, and being careful not to disturb any of the connections to the DVD player, etc.), and then do the unplug/plug thing. We're guessing that moving the back panel around is essentially facilitating the unplug/plug thing.
Our repairman discovered this when he tried to fix it the first time. He removed the back panel but then the TV immediately started working, so he couldn't determine what the actual problem was. He gave it back to us, and it worked for a few months and then the problem came back. We did the panel/unplug/plug thing and it started working again.
Hope this helps!!
Oct 18, 2008 | Televison & Video
Rca d52130 herd pop tv went dead
dear friend your tv has a defective fly-back transformer 99 times out of 100 that is your problem.
get the model number and call your local electronics parts distribuitor to see if they have it, if not call tritronics 1800-638-3328 they probably have it and is not too expensive.less than $25.00.now when you get here is the million dollar question can you do it yourself? if you can't call the repairman and by having the fly-back that will decrese the cost of the repair, is just the labor.
good luck
caypianan@yahoo.com
Sep 02, 2008 | RCA D52130 52" Rear Projection Television
I have no power
look on the back and see if its itc222 chassis if it is you can get the complete service manual and free tech support for your tv this set is famous for bad fly backs and if it is you can also order your fly back at that link also with free tech support
http://servicemanuals.vstore.ca/
Apr 12, 2008 | RCA P52955 52" Rear Projection Television
RCA
sir/maam i think thers a problem with its fly back,,,,,or its power supply going to the picture tube????kindly check it out thanksss and hope too help you!!
Feb 20, 2008 | Televison & Video
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
Apex Digital AT2708 27" TV Logo
67 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
