Question about HP Photosmart 3210 Printer
How to fix--"error processing command"?
When I go to the printer cue, at the bottom it shows "error processing command", when I try to print a computer manual. I can print from Word with no problem
SOURCE:
leroyal
  • 2120 Answers
SOURCE: HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Posted on Feb 26, 2009
SOURCE: Error Message HP Cue DeviceDiscovery Services - HP Laser M1522nf
Go to HP as per attach link http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-56725-2 and download the software. After extract it to another folder, and click install. Voila the printer now work like a charm.
Posted on May 02, 2009
sonu_sehgal
  • 421 Answers
SOURCE: hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Posted on Jun 03, 2009
SOURCE: Printer Error Code 20 HP Deskjet
I have a c3100 HP printer. When i try to print from Word, it indicates a problem code 20. How do I fix it?
Posted on Aug 12, 2009
  • 1751 Answers
SOURCE: message says paper jam- Printer shows E - will not
Hi
replace cartridges
Posted on Nov 21, 2010
Computer says printer has 6 documents waiting but yet when I click print, the printer does nothing.
do you have more than 1 printer installed and if so what printer is selected?when it shows 6 docments in the cue what is the printer called in the cue? Try deleting printer and re-installing driver.You could have a corrupted driver.
Mar 20, 2014 | HP Office Equipment & Supplies
My dell dimension 2400 series computer has lost comms with the local dell AIO A920 printer. Connections seem to be good. It seems a print job has got stuck somewhere. HELP! AJCook
how your printer icon is looking on control panel, if dim, it means it is not detecting , if normal it means detecting then,
go to control panel open printers, then open your printer, cancel all the documents, then send a print command and check
Nov 01, 2008 | Computers & Internet
Printer error, needs troubleshooting - printer worked last week, now it hold prints in cue, windows troubleshooting is not solving issues 7310 hp office jet, tx
Hi
Maybe the print spooler service had stop and needs to stop and restart again. Please try this solution.
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
If not, try to set up or add once more the printer to correct any printer driver corrupted files.
Or if not, uninstall and reinstall the pirnter driver and then, add once more the printer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 11, 2011 | HP OfficeJet 7310 All-In-One InkJet...
PCL XL error Error: InsufficientMemory Operator: EndPage Position: 152856
Add more memory into your PCL printer -- each printed page is produced by your printer processing the PCL (Printer Command Language) commands. The page that you are trying to print is "too-complicated" for the printer to generate, giving the limited amount of RAM currently installed in the printer.
Or, reduce the complexity of the page that you're trying to print.
Aug 04, 2010 | Computers & Internet
Print jobs stuck in cue
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jun 25, 2010 | HP LaserJet 8500 Color Printer
I have a problem with t644 indicated 900.00 service rip software before this error printer indicated 960 service.after turn printer off then on error code indicated immediatly
Try this...power off printer. Then if it is a network printer go the to print server and clear all the documents from the print cue. If it is a local printer clear all documents in the local print cue then power the printer back on. Once the printer powers up the error should clear, if it doesn't clear power the unit back off and ensure that all documents have been removed from the print cue then power printer back on. This worked for me on the C782e, x854e and x940e models that I have.
Jul 04, 2009 | Lexmark T644 Laser Printer
900.80 Service RIP Software
install your printer driver again....
May 20, 2009 | Lexmark X642e All-In-One Laser Printer
Feb 26, 2009 | HP LaserJet 4 plus Printer
Not printing
pls reomve all the print job from print spooler like just double click on the printer icon it will shows the list of pending job pls clear all the documents and restsrt the sytem and then give the print command it will work.
Oct 09, 2007 | HP DeskJet F380 All-In-One Printer
HP Photosmart 3210 Printer Logo
360 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
