Question about Nemox Coffee Makers & Espresso Machines
Bean hopper for Nemox Lux broke. Where can I get replacement?
espressodoc
  • 29 Answers
SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Posted on Aug 15, 2007
  • 70 Answers
SOURCE: Poured water into the bean hopper by accident
I wouldn't recommend it. Grinder needs to be opened up from the top where the ceramic blades are and that section needs to be cleaned out. The coffee in there will compact and mold quickly. Just unscrew the top screw by the hopper. There should be a rubber circular housing you can remove. From there set the grinder setting to the coarses setting (all the way to the right, and not 1.) Look at the blades and there should be markings in red and blue, align the red with red or blue with blue until the top blade easily detaches. Clean inside the that area and **** out all the coffee. Replace top blade, set red to blue so it locks the blade in place, replace arm and hopper.
Posted on Jun 09, 2009
VtToolMan
  • 704 Answers
SOURCE: Is it possible to get a replacement bean hopper?
Yes, you can purchase just the hopper assembly for around $10 directly from Cuisinart. Here's a link to their web site and the parts page for grinders.
http://www.cuisinart.com/parts/coffee_bar/dbm-8.html
I would also give them a call, as they are pretty well known for excellent customer service and you might get the replacement part for free, if you're still within the warranty or close to it. Give them a call using their contact page, as I'm not sure if you're in the USA or somewhere else in the world.
http://www.cuisinart.com/support/contact.html
US Customers can call 1-800-726-0190
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
Testimonial: "Response was quick and clear. I was able to order the part I needed, and really do appreciate the help."
  • 9 Answers
SOURCE: i have a s9 avantgarde keep getting error fill bean
Seems Problem with the bean sensor. you need to get the same replaced. there are no setting that can be done manually for bean sensor.
A Jura Engineer can check the Bean sensor with his computer system and confirm if the bean sensor is faulty.
Posted on Oct 16, 2009
EsWorld
  • 1618 Answers
SOURCE: Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Posted on Nov 05, 2009
Testimonial: "It was helpful, but I already cleaned and vacuum the brew grind unit. The grinding mechanism is turning, but no coffee is dispensed. Any ideas?"
The bean container/hopper on my Capresso 560.01 Infinity Burr Grinder is stuck and can no longer be rotated in either direction or removed from the body. Can anyone help me unseat it?
Grinders that are used daily, especially those in coffee shops will eventually wear out. The fine settings for espresso (or even finer for Turkish grind) will wear out the plates even faster. I've seen burrs needing replacement in 3-6 months for coffee shops. Burrs set on this fine position that do not grind or stop usually means a worn burr or gummed up plate. (especially with oily beans). Either problem requires the removal of the burr set and complete disassembly of the grinder. It sounds like your '1st' problem was corrected by permanently 'affixing' the burrs to a set position and now not able to remove them without causing more damage. I did the same to an old grinder I got from the swap meet. But alas, the plastic collar cracked completely and can't be repaired. well got 1 year's worth of use and it was cheap.
** Suggest checking with your vendor or MFR for service and/or replacement.
Aloha, ukeboy57
Dec 08, 2017 | Coffee Makers & Espresso Machines
My machine is having a problem grinding the coffee it is gringing it but very slowly
HI
Its probably set to fine in the bean hopper. The big knob in the bean hopper should be set around 8. If its lower than that you need to turn it up. If you have 2 knobs in the bean hopper you can turn the small knob towards the + side, but not all the way for stronger coffee.
Jan 15, 2011 | Gaggia Syncrony Logic 74884 Espresso...
My cuisinart cbm-18 does not grind at below a 10 setting?
Hello, and thanks for using FixYa.
I'm guessing the problem is that the grinders blades, or the parts that do the grinding have become somewhat dull, (opposite from Sharp.) and no longer can get to the beans like it used to.
Cleaning the machine properly might improve its performance.
CLEANING/MAINTENANCE INSTRUCTIONS
1. Be sure plug has been removed from outlet.
2. Beans can be removed from the hopper by lifting off the lid and pouring excess beans out. Hold down the Manual button to cleanout any remaining beans.
3. The bean hopper, bean hopper lid, grind chamber, and grind chamber lid can be washed by hand with hot, soapy water or placed in the top shelf of a dishwasher. Dry thoroughly.
a. Remove the bean hopper by rotating counter-clockwise bringing the selector past grind setting 18, align the arrows and lift up. Make sure the hopper is empty.
b. Remove grind chamber by pulling toward you.
4. Remove the burr grinder, once the bean hopper has been removed, by grasping the metal handle and lifting up. Use the brush to remove grinds or wash by hand. Replace the burr grinder onto the unit and rotate until the piece is fully inserted. Push handle down and replace hopper.
NOTE: The hopper will not attach to the unit if the grinder has not been fully inserted.
5. Wipe body of grinder with a damp cloth.
6. Any other servicing or maintenance should be performed by an authorized service representative.
WARNING: NEvER ImmERSE UNIT IN WATER
Oct 14, 2010 | Cuisinart CBM18 Electric Grinder
The plastic shield in the coffee container on my saeco incanto de luxe broke yesterday and fell directly onto the beans, but I was still able to make my coffee this morning, but this afternoon, the...
Vac out the bean chamber, then remove the 2 or 3 screws and carefully lift the bean hopper off the machine, then continue cleaning the grinder, careful not to lose the gasket around the top of the grinder. When done reassemble and try to brew but do not add beans to hopper as yet. Until you are sure all the plastic pieces are out.
Sep 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
What do you do when the grinding blade will not come off for cleaning?
Hi
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Jul 19, 2010 | Solis Maestro G385 Electric Burr Grinder
Cleaned grinder now can't get it set correctly. where do i line up red dots.
Hi
When you put in the outer burr, the redo should be to the front. The outer red dot has to be at the back. Rotate the outer red dot clockwise till it lines up with the inner red dot. Try lifting the burr out to see if it locked in. If it didn't, reverse the process and make sure that you push down on the burr before rotating the outer ring. Move the big knob in the bean hopper to 0 (zero). Put the gasket on the grinder and replace the bean hopper. Once the bean hopper is secure, move the big knob to 8 and you set.
Jan 05, 2010 | Saeco Vienna Espresso Machine
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
I can't remember the simple key to disassembling the Solis Maestro for more thorough cleaning. I need to get beyond the top burr removal stage.
Hi
Rotate the bean hopper counter clockwise until it stops. Lift the bean hopper out. Remove the outer burr with the wing-lets. Can go back in either way. Clean with air or vacuum out grounds. Use small brush to help clean grounds. Reinstall burr. Line up notches of the bean hopper with shell ( large tab in large slot, and small tab in small slot). Rotate bean hopper clockwise a small amount and test.
Nov 10, 2009 | Solis Maestro Electric Burr Grinder
I have a s9 avantgarde keep getting error fill bean even though i have plenty of bean in the hopper
Sep 15, 2009 | Jura Capresso Impressa S9 Coffee...
Nemox Lux Burr Grinder
There are a series of gears between the motor and the shaft. Replacement parts are avaialble ad cafeparts.com under ascaso ibertal grinders. You will need to take the grinder apart to find the problem.
Dec 16, 2007 | Nemox X79751250 Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
107 people viewed this question
Top Nemox Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Nemox Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
