Question about Roper RAB2121KW Top Load Washer
My Roper top loading washing won't stop filling.
My washing was working fine until the other day. I noticed it leaking and that usually means I need to clean the area at the bottom of the drain hose. So I did. Then it would fill up, wash/agitate, drain then start to fill for the rinse cycle. However it wouldn't stop filling. It doesn't overflow because as it's filling it's draining. I had this problem once before and it was the drain wasn't at a proper angle. So I checked that and readjusted it. Still doesn't work. Now it won't fill for the wash cycle. The water just runs and runs, never overflows cause it's just draining out. PLEASE PLEASE PLEASE any help would be great. My mother in law is comming next weekend for the holidays and I am up to my eyeballs in linens to wash!!
  • 246 Answers
It's not necessarily the angle of your drain hose. When it drains as you fill it, it's called a siphon condition. Pull the excess hose out of the stand pipe (drain). Only about 6" should remain inside the pipe. Tie it down with a plastic tie to one of your fill hoses to prevent water pressure from pushing it back out. This should solve your problem.
Posted on Jun 15, 2008
Our Roper Top Loading Washing Machine won't fill with cold water and the machine makes a electrical buzzing noise when you turn it on set to Cold/Cold.
Lift the top of your washing machine by unscrewing the back or remove the back and you will find a code and test sheet inside, you normally will find it at the top edge of the machine from or back. Very easy to use if followed to a T.
Jan 20, 2016 | Roper Washing Machines
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Washing machine was working fine, but leaking water from the bottom. took it to a repairman, he said pumpwas stopped up and he replaced it. hooked it up and it fills with water but it will not start, wont...
if the washer machine idetifies the levels of water (ex low middle high) means that pressure switch works
there are two things!!!!
the switch's door is not working or the switch's timer also doesnt work
if the washer machine doesn't idetifies the levels of water does the problem
Oct 05, 2009 | Roper RAS6233KQ Top Load Washer
Liquid detergent leaking from under control panel
am sending you this diagram to better knowlage of your michine.
this web includs parts, parts #
copy n paste
"Did it solve your problem?"
May 08, 2009 | Roper RAS6233KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washer leaks when running full loads
This could mean the fill level is not working properly and there is an overfill situation. Generally[I don't know 'Roper'] the fill level is controlled by a 'bottle' like device at the fixed to the outside of the drum at the bottom with, with a fine tube leading to a disk like thing near the top of the machine- with wire coming from it to the controller. The 'disk' thing is the pressure sensor. and the bottle thing is supposed to fill with water and the air pressure in the tube actuates the switch in the 'disk' Overtime the 'bottle' will get clogged with crud and need cleaning out. This will mean taking it off and giving it a good cleaning. Hope this helps.
Jul 07, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAB2121KW Top Load Washer Logo
193 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
