Question about ASUS AiLifestyle P5KC Motherboard
Esata controller does not see my WD My Book Home Edition
It simply writy while boot - ''No device found'' =( Can I do something to resolve this trouble?
  • thonik Jul 03, 2009
    Nooo!
    It's a external drive with external power. It connects to PC via USB or FireWire or eSATA. USB and FireWire connections works good, but I want to connect it via eSATA port.
    Champion:
  • 253 Answers
I got the same problem...and resolve almost the problem.
It still doesnt see the hd in the boot `, but when i turn on the hd before the pc is on so the p5kc found the drive.
Posted on Oct 22, 2009
  • 784 Answers
If your WD id IDE
There is 2 ports for IDE master and slave you can try to swap to see it can recognize providing you set the correct jumper for M or S.
If your WD is SATA
There is more than one of SATA ports you can try to connect for every boot.
If it doesn't recognize, either bad board or bad WD
Posted on Jul 03, 2009
K:\ is not accessible the request could not be completed because of an I/O device error
The HDD may be bad, Has it been dropped, jarred, etc.? Remove the HDD and test.
Feb 14, 2013 | Western Digital My Book Home Edition 500...
Need a user manual for "my Passport" 750 gb WD hard drive
click on this >> Link << for the Manual for your device.
Hope this helps.
Jun 18, 2010 | Western Digital My Book Home 750GB...
My book essential edition 160 gb
If it hooks up by USB it really isn't designed to boot up. If it is hooked by an external eSATA plug, and your set up will allow you to choose that as a boot up device it can be done. But life would be a lot easier just making a simple boot up disk on a DVD or CD.
May 29, 2009 | Western Digital My Book Essential Edition...
ESATA Connection problem with My Book & my laptop w/ Vista
Had the same problem with a WD esata 1TB drive and an HP DV6 laptop. Using Vista home premium. Lots of experimentation BIOS settings and driver update, and finally fixed it by trimming back a couple of mm of the plastic shoulders on each connector of the esata cable. A few depth measurements and it became clear that the connectors weren't going in deep enough otherwise. The cable was a Belkin of reasonable quality.
No problems now, but the drive is only recognized if it's connected at boot-up.
The core of the problem is the external casing of both the laptop and the WD drive enclosure. They're thick and keep the cable connector from going in far enough. Perhaps manufacturers of the cables or the esata devices are sloppy, or the standard isn't specified well enough. I've seen pictures of esata cables that have significantly different dept.
May 14, 2009 | Western Digital My Book Essential Edition...
WD my book home edition is very slow. help how to make it faster i have tried to unplug it and everything it has been stuck on 67% for about 2 days what to do
Shutdown Windows.
Disconnect the device.
Restart Windows.
Reconnect the device.
Open "My Computer".
Right-mouse click on the drive-letter for the device.
Click 'Properties'.
Click 'Tools'.
Click 'Check now' to confirm that the file-system on the device is OK.
Apr 09, 2009 | Western Digital My Book Home Edition 500...
Wester Digital My Book 1 TB problems
Try booting your computer first and then connect the usb cable to the usb port on the computer. Connect the power supply cord directly to a wall socket. Also try the usb cable on different usb ports on the computer. If possible also try it with a different usb cable. If nothing works, check the file format system under disk management, you might have to re-format it.
Aug 10, 2008 | Western Digital My Book Essential Edition...
Reset password won't work
How to reset the username, password, and network settings of a WD My Book World Edition hard drive. trnsp.gif Answer The directions below detail how to reset the username and password (for the Shared Storage Manager utility), and network settings of a WD My Book World Edition hard drive by using the recovery button on the back of the unit.
  • The username will be changed to "admin"
  • The password will be changed to "123456"
  • The network settings will be changed to DHCP (obtain an IP address automatically).
    1. Please ensure that the WD My Book World Edition hard drive is turned off and all cables are disconnected from the unit.
    2. Insert a paperclip or narrow tipped pen into the recovery slot on the back of the unit. Press and hold down the recovery button.
    3. While continuing to hold down the recovery button, connect the power cable to the back of the unit.
    4. Hold the recovery button down for at least 40 seconds while the unit boots up and then release the button.
    5. The unit may take up to three minutes to boot up completely. It is only necessary to hold down the recovery button for the first 40 seconds of this boot up process.
    Note: Western Digital recommends rebooting the computer system after making any network setting changes to the WD My Book World Edition hard drive.
  • then from WD software select General Setup->WD Anywhere Access settings->Reset.
    Jan 11, 2008 | Western Digital 500GB My Book World...
    Win98se i did it ... HERE'S HOW
    OK, I bought this Western Digital MyBook 500 GB Essential Edition too, and could not get it to work with Windows 98 SE.
    I followed the above instructions, but my version of windows was missing even the drivers suggested above! UGH!
    HOWEVER, I found ANOTHER SOLUTION. I installed USB 2.0 drivers for mass storage and the the MY BOOK icon popped up on my Windows 98 SE machine. Hurray! Hurray! Hurray!
    Here are the drivers from this british webpage:
    http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
    Good luck to all you frustrated folks scooping your info off Windows 98 machines!
    Dec 29, 2007 | Western Digital My Book Essential Edition...
    ASUS AiLifestyle P5KC  Motherboard Logo
    357 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
