Question about Whirlpool LER5636P Electric Dryer
Whirlpool gew9200lw1, dryer does not heat everything checks out ok, replaced electronic control worked for a day then stopped working please help. The sensor and wire harness reads a short and no continuity does that affect the heater
    Sergeant:
    Champion:
  • 289 Answers
If limit switch has no continuity than it is bad,the heater will not come on.before you change the switch you nead to make sure that you do not have a blockage in your vent hose,make sure vent hose is clear from dryer to outside vent.a blockage in the vent hose will cause the high limit switch to go bad.
Posted on Dec 27, 2009
Fault code 8 on a whirlpool duet front load electric dryer GEW9200LW1
Could be bad heating element, bad high limit thermostat or bad cycling thermostat. All of which can be ohmed out with a standard ohm meter. If you replace one I would replace all of them, if you don't you will be going back in there later and replacing another one of those parts
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 16, 2017 | Whirlpool Dryers
Whirlpool duet dryer GEW9200LW1 heats
If the element was replaced, and now verified that it is not presently shorted to ground, your next diagnostic would be to to test the timer connections per the schematic lookiong for a fused contact that energizes the heater, while set to air fluff setting.
Apr 08, 2014 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Dryer - Working but no heat
i need help fixing my 5 year old dryer. whirlpool duet model GEW9200LW1. I have replaced the thermistor. I tested (with an ohm meter) the heating coil, thermal fuse, high limit thermostat, & heating element and they were all fine. I replaced the electronic control assembly and the user interface. THE DRYER STILL WONT HEAT.
Then it occurred to me that the sensor may not allow the dryer to heat if its not sensing wet. Could this be true? Have I been trouble shooting this wrong?
Help me.
Dec 16, 2007 | Whirlpool GEW9250 Electric Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
473 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
