Receivers
Problem for Receivers
Generic problem for all Receivers
No Sound - LCD Volume says 99
By darw on Nov 10, 2007
My ONKYO -TX-SR601 just stop working. The LCD says Volume 99 but it has no sound. the knob and remote wont change it.
Same Problem
Jan 08, 2008
-   I've opened the receiver, check all fuses, clean the circuit plate. Nothing seems burned, but still not working. Any suggestion?-   sendra
Jan 03, 2008
-   Same problem, LCD volume says 99. If headphone is conected LCD volume says MAX.-   sendra
Dec 01, 2007
-   i have the same issue in my TXSR601 receiver. The volume went to 99 and there was no sound from my speakers. There was no popping sound or anything. The volume control knob was not working as well. I removed the connections immediately and tried turning on the receiver stand alone. Still the volume is stuck at 99. I am unable to get through Onkyo support. All other functions in the receiver seem to be responding. Can someone please help?
Did the proposed solution work?
-   tempguy
Solution #1
posted on Nov 10, 2007
Not Helpful)
Savannah Sam
Rank: Apprentice
Rating: 50%, 3 votes
- make your room as quiet as possible, then put your ear next to one of the tweeters (high frequency speakers; the smaller ones).
- If you hear any noise, probably a soft rushing noise or a hum, then your problem is probably an input source problem, not the amplifier itself.
- Plug in some headphones, and see if you can hear your music that way. If so, then the problem is probably the amplifier section, or your speakers, or your speaker connections, not an input.
- Turn the volume down, then look to see if a Tape Monitor button is pushed. If so, "unpush it".
- Check for any mute function that might be enabled.
- If you hear NO NOISE with your ear next to a tweeter, then verify your speaker connections; and check for blown speaker fuses (you'd expect to see a matched pair, one per channel).
- also check your speakers to see if they have fuses
- double-check your speaker connections; verify no shorts, and tight mechanical connections
Was this helpful?
Yes
No
Solution #2
posted on Nov 01, 2008
Not Rated)
a-mused
Rank: Apprentice
Rating: 0%, 0 votes
Found a solution that works. Power down the receiver. Unplug it from the wall. Wait 10 minutes. Plug it back in and power it back up. Worked like a champ to fix this exact problem with my TX-SR601.
Was this helpful?
Yes
No
Popular Solutions for Receivers
Questions and Unsolved Problems for Receivers
Answer
When plugged in it says overload. How do I fix this?
Answer
Roland 5500 keyboard buzzes at nearly all volumes.
Answer
Sony TC-WR670 - Turn power on. Press eject button. Put a tape in the deck. Closed the deck. Pushed... (More)
Answer
Nakamichi RE-5, CD-5, MD-5 (Receiver, CD-player, MD-player) connections? I've lost the manual and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Receivers Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
