Question about Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television
Display problem I have a philips 32TA1000/98. If you turn on the power it just flicker and flicker. It will not stop until you turn it off... Please help...
I HAD THE SAME PROBLEM AND IT WAS 2 FAILED CAPACITORS ON THE POWER SUPPLY BOARD. REPLACED THEM MYSELF FOR $1 EACH! WORKS FINE NOW
Posted on Oct 08, 2011
    Sergeant:
    Champion:
  • 245 Answers
Check ur power outlet and cable and make sure its plugged in well........also check power cable if not damaged........if so get it replaced
also ur antenna may got a loose connection on the mast or antenna input on ur pc......
Posted on Jul 03, 2009
Flickering screen
hi. you problem maybe in power supply unit. couple capacitors bad between power supply to inverter board. good luck!
Sep 22, 2012 | Philips BDL6551V 65 LCD flat panel display...
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
Monitor is 22" Samsung 226BW. Problem is that it was blinking for a long time after I turned it on and after a while it would become stable and it was working fine until I powered it off and on again. Now...
The blinking or flickering problem you are having is caused by the power supply failing. There are parts called capacitors that start to fail which causes the voltages to not stabilize. When they rise and fall the display flickers until the voltages settle. We have an article posted on our web site at http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ that explains what needs to be replaced and includes pictures with part lists. If you don't want to do the repair yourself we do offer a repair service, more information on this service can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 22, 2010 | Computers & Internet
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Not turning on
tv will not turn on by remote or power button on the tv
Aug 31, 2008 | Philips 17MD250V 17.1 in. LCD TV/DVD Combo
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
New Philips voip8411b phone
I have the same problem and could not find a contact phone or e-mail. Can you tell me the e-mail you used. Thanks.
Dec 07, 2007 | Lands Phones
Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
