Question about Acer Computers & Internet
DVD/RW IS NOT WORKING CODE 39
My DVD/Rw is not wporking the code 39 is display
  • 144 Answers
I was fixing a computer the other day and ran across the following error in Device Manager on the CD-ROM drive.
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful.
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot
your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
If you found this helpful , please rate my solution below :D
Kind Regards
1234s282
Posted on Jul 03, 2009
    President:
  • 1,257 Answers
Click on the link below to fix the issue.
http://www.windowsguru.org
Posted on Jul 05, 2009
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
What brand of DVD+RW will work in RCA EZDVD1BD?
Rule of thumb. a DVD-R is the most reliable and will work in ANY DVD RECORDER. ALL RW discs are hit or miss and not reliable, no matter who makes them. DO NOT BUY discs made by Maxell or Memorex. They are **** and should be illegal to sell. Verbatim brand is by far the most reliable. If you are buying RW's because you want to reuse them over and over...give up and use -R's. your life will be much happier.
Aug 02, 2012 | RCA EZDVD1BD Digital Camcorder/ DVD...
I get error code Disc error 972. Is there an easy fix for this Regards Steve
From what I can tell, this error is caused when you've burned your own disc on a DVD+R/+RW. The Wii console only supports DVD-R/-RW. Check your media to see if you have DVD+R, and, if so, try burning onto a DVD-R (or DVD-RW, in case it doesn't work) and check it in your Wii again.
Jun 21, 2011 | Nintendo Wii Console
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
I need to fix a problem with my Sony DVD RW DRU- 180A. I get error code 39. The computer doesn't seem to recognize the DVD player.
More than likey a fault in the DVD player.
Did it work recently?? If so then probably faulty.
Check internal cable and even try another one, I have had the occasional cable fail.
Dec 22, 2009 | Sony DRU 180A - Disk drive - DVD RW ( R...
OPTIARC DVD RW AD -7530B ATA DEVICE NO FUNCIONA
From your description I understand that the DVD drive is not working and you have code 39 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Nov 23, 2009 | Microsoft Windows Vista Ultimate Edition
Pioneer dvd-rw dvr-k17a
I fixed it my self, redownloaded my Windows and repaired it.
Sep 08, 2008 | Pioneer DVR-107D DVD±RW Burner
HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Feb 29, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Computers & Internet Logo
209 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
