Usb mouse move itself,cursor jumps unexpectedly
I have a microsoft usb mouse .its cursor moves or jumps some where in desktop, if i want to click on start button some time it goes some other place
    Sergeant:
    Champion:
  • 245 Answers
Go to ur control panel and click on mouse ...u may have to reset ur settings
if this not work uninstall ur mouse in add/remove.......and then reinstall software
Posted on Jul 03, 2009
  • Kareem Ahmed
    Kareem Ahmed Apr 25, 2014
    I am always fond of the Logitech products, although, I think that in the past they had a better quality.
  • Kareem Ahmed
    I had the same problem, and it drove me crazy. In my frustration, I almost broke the mouse, by smashing it very hard in my desk. The problem is the mouse becomes almost unusable and it drains your batteries. It is strange the mouse behaves like this, because before it did function perfectly. I my search, what could be the reason, I tried everything that you can find here and on other fora related to this problem. Test on another PC, the same problem. Different Drivers. Different USB port / try PS/2. Different mouse settings. No power management on the USB port. Different mouse mat (Dark and non reflective). No other device on the same USB port. No other radio controlled devices near. No wireless telephones near. I also opened the mouse and cleaned the lense, no improvement. I also removed the lense, and cleaned the micro camera, that is behind the lense. It all didn't solve the problem. I tried to adjust the distance between the PDB (optical micro camera) and the lense) it did not solve the problem. The mouse did not move at all anymore. Nothing worked. But I noticed, that when the mouse is on a light surface, the problem becomes worse. So a simple conclusion was, that it had to be light strength or focus related. HERE COMES A SIMPLE TEST, AND IF THAT WORKS, I HAVE THE SOLUTION FOR YOU: Lift your mouse a few millimeter above the mouse mat, and increase the distance, while moving your mouse. Stop rising the height above the mouse mat when your mouse pointer does not move anymore. Lower the mouse a little bit and hold it very steady. Do not move. When your mouse does not move by itself anymore, I know the solution. I told you, when I used the dark mouse mat, the problem was less than with a light mouse mat. That made me clear, the problem was light strength / focus related. When there is too much light, it is hard to read. It is the same for the mouse, too much light, and the mouse cannot focus anymore. It does get blinded. SOLUTION: I opened the mouse and thought of a simple and low tech solution, how I could decrease the LED light strength intensity. I took a paper multi layer tissue and pealed off a single layer. I cut off a small snippet of about 6mm wide and 1,5 cm long. I fixed one side against the LED. The other part, I used to fix it on the PCB by some sticky tape. Make sure, that the tissue is not against the lense that comes after the LED. Because that will cause problems. All you want, is to reduce the light intensity slightly. Not introducing a light pattern. If the paper is against the lense, it disturbs the light pattern, that the mouse needs to focus and notice movements. After I placed the small piece of tissue, all the problems, were solved. The mouse functions again as when I just bought it. CAUSE: Probably, one of the components on the PCB degrades in quality over time. In this case probably a resistor that controls the power the LED receives. Since the mouse PCB contains all micro electronics, I do not advice replacing any of the components. The LED in my mouse, has very long wires, so it is easy to cut one of the wires and experiment with placing an extra, low resistance resistor in the line. It will also improve the battery life length, if you do so. But I used the low-tech solution. This also solves the problem, that the mouse does not go to sleep mode anymore and drains your batteries in a few days.
How do I connect a microsoft wireless moblie mouse 3000 to my laptop?
Press the button on the back of the mouse to free the battery cover on top.
Remove the battery cover and put the supplied AA battery into the mouse.
Replace the battery cover.
Insert the wireless USB dongle into a USB port on the laptop or desktop computer.
Move the mouse and watch your computer screen.
Confirm that the mouse is connected by making the cursor move.
Hope this helps
Sep 26, 2012 | Microsoft Wireless Mobile Mouse 3000
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My wireless mouse - cursor refuses to follow sometimes!
check the laser for debris and try plugging the usb adapter into another port.
Mar 21, 2010 | Dell Computers & Internet
I have a usb mouse that recently has stopped moving correctly
hi frnd... Mouse works fine only on plain surfaces.. mattress are not straight so they might create problem...
Sep 29, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Mouse moves, click and drag by itself
That sounds a lot like someone has remote access to your computer. Try changing your Firewall settings or try to get a different IP address. Careful messing around with the IP though, it's easy to create a problem when doing that.
Jul 08, 2009 | Microsoft 2000 Wireless RF Optical Mouse
Mouse cursor moves, but mouse clicks do not register
1st mite have a virus or you need to redownload the driver for it try rebooting it .
Apr 14, 2017 | Logitech Wireless Access Duo Optical...
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
USB mouse is jittery
Try the mouse on a different surface, also be sure you do not have any light directed at the mouse - this confuses the eye. Although no mouse pad is required for an optical mouse, sometimes it helps
Apr 01, 2009 | HP USB Optical Scroll Mouse
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Acer Vista Laptop and cursor nightmare!!
Hi -
I've been having the same problem and it is MAJORLY annoying to be typing along, and have the cursor reappear on another line!
I had a heck of a time finding the place to disable the touchpad, since we use a USB mouse with the laptop. Turns out, someone else helped me find a simple way - hold down the Fn key (next to the left side CNTRL key), and hit F7. That toggles the touchpad off/on easily!
Also suggested by someone else, some mice can cause erratice behavior with Acer laptops, so perhaps try another mouse?
So far, I've been typing this response AFTER disabling the touchpad, and the cursor has not jumped around at all.
Good luck! : )
Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
872 people viewed this question
David Payne
David Payne
