Question about Epson Stylus C88 InkJet Photo Printer
My Epson C 84 had something jammed into the paper feed and once the item (a blind pull from the window) was dislodged it will not fee paper or print. any words of advice?
  • 353 Answers
It seems likely that the feed mechanism has been dislodged or broken in some way.
Look down into the place where the paper goes (the "automatic sheet feeder" or ASF) and you should see a fat wheel with a grey ribbed rubber facing. Place a single sheet of paper in the ASF and do a test print (right click the printer icon and select properties). Watch to see what happens in the ASF. The plastic panel behind the sheet of paper should move forward to push the sheet against the rotating rubber wheel, which should then feed the paper into the print position. If this is not happening you will need to dismantle the printer to investigate further.
If you wish to do this, post a new comment to this effect and I will provide further help.
Posted on Mar 01, 2009
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Epson wf-2530 printer error see your documentation
Turn the printer unit ON
2. Pull the power plug from the back side of it
3. wait 1 min
4. Plug unit back in
5. wait 3 full minutes
6. try to print does the error still exist? If yes continue below
Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away.
If you continue to experience problems, PLEASE RESPOND TO ME
Dec 16, 2013 | Epson WorkForce Office Equipment &...
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus CX5400 Won't stop jamming!
If the paper isnt being pulled in the chances are that you have a foreign object in the paper path. First of all turn the printer off & disconnect all cables. Turn the printer upside down and give a good shake, with luck the blockage should fall out. If not then you need to be a bit brave, make sure the print carriage is parked fully to the right and out of the way. You will need an A4 (approx) sized piece of stiff cardboard such as the backing from an A4 note pad. Insert this into the paper feed locating it between the feed rollers on the R/H side. Then push quite firmly to overcome the spring pressure, when you feel it push through about a half inch stop and open the printer to see what is being pushed through. Push the card fully through and retrieve the foreign object (I have found everything from paperclips, curtain hooks and even a golf tee!). Push the card through fully and out of the printer. Always remove paper jams etc, in the direction of the paper feed whenever possible as pulling anything backwards can dislodge or break the sensor flags.
Hope this helps. Please take a moment to rate this solution, thanks.
Apr 14, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Epson stylus photo r340 paper feeder
the friction feed roll might be dirty from paper lint, ink glazed or it might have something stuck in it ( a piece of paper from a jam etc.)
Jan 29, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus C88 InkJet Photo Printer Logo
133 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
