Question about Lexmark C530dn Laser Printer
I have a Lexmark 530dn. It will not print out straight on anything heavier than card stock. It also leaves a film of grey on the printed side. I checked my ink levels and they are all really high. Please help. I'm about to chuck my printer out the window!
  • 112 Answers
I think your printer to be serviced, just take it to the shop and ask for it to be serviced. thank would help, those film lines are from the drum and it need to be clean. just take it to the shop for servicing your printer will be fine again. thanks
Posted on Jul 03, 2009
I'm printing on 110 lb card stock and the toner gets crispy..and actually flakes off on the edges and sometimes leaves smears and clumps of black or burnt toner on the paper. It prints fine on 20 lb paper...
could be the fuser but there is a setting for heavy paper or card stock which will slow it down and increase the heat. depends on your model as to where this can be changed.
Jul 27, 2017 | HP Color LaserJet 2600n Printer
Up to what weight paper can I use in my HP Color Laserjet 2600n
Usually you can print up to about 60lb paper. You may be able to go as high as 90-110 (card stock) if the paper print path is straight thorugh. If you printer has a rear paper door then you can try heavier paper. Usually 40-60 is safe for printer without a rear door/heavy paper path.
The problem is that the heavier paper cannot bend around the rollers inside. So if it is setup to allow heavy paper it runs through flat and out the back instead of curling around and out the top as normal.
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Print wedding announcements and the print is not straight
Card stock on an HP can be a nuisance, due to the paper feed path. The stock has to curl around the platen.
Some things to check: Make sure you are telling the print driver you are using card stock. It should be in the printing preferences as paper type. The printer will respond differently, knowing it has the heavier paper. Also make sure that your paper guides are adjusted to fit the smaller stock. Just putting in 5.5 x 8.5 paper into an 8.5 x 11 tray may cause it to skew.
I am assuming that you are already telling it to print high quality, as it is for a wedding announcement, but make sure that you are. Slowing down the paper feed speed by putting it into high quality mode can help.
Your printer is an older model, so it could be that the rollers are wearing down, and it just can't feed the last bit as well. You could try to print it in "landscape" mode. Turn the paper 90 degrees in the paper tray, so that the 8.5" is the feed side. This will allow the printer to have a better grip on the paper as it goes through. A word of caution with this method, though. HP's have a 1/2 inch margin at the bottom of the paper where it can't print. Turning the paper 90 degrees will force you to have a side margin of 1/2 inch. Currently, your bottom margin has to be 1/2 inch. I don't know what your layout looks like, so I don't know if you can turn the paper.
If you are the one getting married, the congratulations, good luck, and mazel tov! (Have to cover all the basis).
Jul 17, 2009 | HP DeskJet 5550 InkJet Printer
Printing on business card stock
goto avery website and download designpro for free it has all the templates for avery stationary
Mar 18, 2009 | Lexmark X6570 InkJet Printer
Lexmark, paper jams and prints in same place, over+++
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | Compaq Lexmark Color Jetprinter Z12 InkJet
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
Printing on to black paper
I'm sorry, but there is no white ink in the cartridges in this printer, and there are no printers I know of by any manufacturer that have white ink to do what you're wanting to do.
All I can suggest is these two things:
  1. Go to a local printing shop and see if they can do this for you. I used to work at an Insty-Prints and they could do thermographed ink (which means the ink is slightly raised, like you see on some business cards), and probably have white or light grey ink. They may be able to do this for you.
  2. Alternatively, you can print it on your printer, but you'll have to use white card stock and have the printer print all the black (and leave the white areas white). This will use a lot of black ink so if you have a lot of these to print, it might actually be easier and cheaper (considering the cost of ink) to again go to a print shop in your area.
Aug 12, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Printing Business Cards on Cardstock
It could be.
Part of the problem with that machine is that it has to bend the paper to get to the inkjets. If its too think it will stop running.
We use this Avery stock for printing business cards that might be a little thinner cardstock. I would look for some recommended for ink jet printers.
Jun 13, 2008 | HP Officejet 5610 All-In-One InkJet...
PRINTING W/CARD STOCK
Use the Manual feed tray and have it on printer setting medium. Make sure it exits out the back.
You have to babysit heavier stock and give it a nudge sometimes.
Mar 23, 2008 | OKI C5500n Printer
Lexmark C530dn Laser Printer Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
