Question about GE Dryers
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
Blows cold air, no noises, vent hose clear, less then 5 years old(if i remember right) will continure to run until i open the door
    Problem Solver:
  • 4 Answers
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Posted on Sep 12, 2014
4 Suggested Answers
SOURCE:
  • 1218 Answers
SOURCE: dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Posted on Mar 02, 2010
Macmarkus
  • 2605 Answers
SOURCE: My dryer is not producing
Hello, welcome to FixYa.
I'd suggest you confirm you have 240vac supplied to the unit first, if not turn off the breaker all the way and then back on...if yes, move on.
Next, remove the access panel in the front bottom and inspect the wiring and heating element...if you haven't done so already. You will need an ohm-meter or multi-meter of somekind to be thorough.
**Be sure to unplug the unit before servicing...safety first.**
Let me know what you find and we can go from there. Good luck.
Regards,
Macmarkus :)
Posted on Jul 22, 2011
SOURCE: Dryer is only 5 yrs old. Started to blow cool
There is a device in the circuitry for the heating element which shuts off power to the heating element when the dryer gets above a certain temperature which is ealsily reached with a clooged vent hose. This device, a thermal limit switch or thermal fuse, cannot be reset, it has to be replaced.
If you want to do this yourself, let me know -- if not, you will need to arrange for someone to repair the dryer. The device costs about $20 -- a service tech will probably charge up to $150 for the repair.
Charlie
Posted on Jul 26, 2011
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Takes several cycles to dry
My heat isn't working..the fan blows cold air
Depending on the year make and model, it could be a blend door problem if the heater hoses are hot.
Oct 08, 2012 | Cars & Trucks
Dryer is only 5 yrs old. Started to blow cool air. Not heating. Vent was blocked from outside. Cleared vent, flab is open, but dryer still not blowing hot air. Is there a reset on this machine? Why...
Charlie
Jul 26, 2011 | Kenmore 600 7965 Dryer
I have a 5 year old heat pump (electric) Home is 5 years old and is very energy efficient with 6 inch outside walls. Do I have a problem as the air will run for 5 minutes and shut off for 5 minutes and...
One thing you might check is to make sure there is not cold air blowing across the thermostat from one of the vents. I've seen this many times make the thermostat short cycle.
Some less expensive thermostats may be programmed to short cycle. If you have instructions available for the thermostat, try to find information or the "heat anticipator". It may have an adjustable setting.
Jun 30, 2011 | Heating & Cooling
Dryer will not turn off is it the timer? the dial does not move
do you have heat?when the dryer heats up the timer doesn't move,when the heat shuts off the timer moves,when the heat comes back on the timer stops,the timer will not move if there's no heat.if you have heat it could be the timer.also run the dryer when it's cold for 15 to 30 minutes and check to see if the flame is still liting,there's a little cover on the front panel that you can pop off to see the flame,there's a set of gas coils on top of the gas valve that when they fail they will stop working when they heat up,when the coils cool down they will let the gas through and the flame will lite again,common problem with gas dryers and most likely your problem.also when was the last time you cleaned out the dryer,you need to blow out the vent line if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the line,make sure the outside vent is clear so the air can blow through,next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year moreso with gas so you don't have a fire,also your clothes will dry on time and you'll have less problems with the dryer.let me know what you find.
Apr 18, 2010 | Kenmore 73952 Gas Dryer
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer runs...timer wont rotate and wont heat up
Good day,
Mar 02, 2010 | Whirlpool Dryers
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
200 people viewed this question
Top GE Dryers Experts
vince
gbob59
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
