Question about Nokia 6288 Cellular Phone
Problems! hi ums i got a nokia 6288 yesterday and yesterday when i plugged it inot my computer to put music into it. it just turned off. so i try to turn it back on again but it just flash a few times then off..please helpxoxLiennee
  • 490 Answers
Re: problems!
Take back up of ur phone & try with normal reset or with hard reset dial *7370# it might lost some data so plz take back up before doing it . or try with other h set or for more support contact service centre good luck
Posted on Nov 10, 2007
0 characters
3 Points
Nokia 6288
just buy a flex then change the flex of ur pone
Nov 03, 2008 | Nokia 6288 Cellular Phone
Nokia 6288
press the menu option while the music is playing so that you can access other applications but it will make ur phone processing very slow!!..
Jul 16, 2008 | Nokia 6288 Cellular Phone
6288 soundless
Try this code *#4720# . It might or might not work. It's a deactivated low sound volume to save battery.
Apr 06, 2008 | Nokia 6288 Cellular Phone
Want send MMS but if want inside Foto is always restrat ( nokia 6288)
Can you browse internet or wap pages via GPRS? What is your carrier?
Mar 11, 2008 | Nokia 6288 Cellular Phone
Unable to format my nokia 6288
Fully charge the battery, then power the phone on while it's still plugged in to the charger. Now you should be able to power the phone on and delete all those messages.
Jan 20, 2008 | Nokia 6288 Cellular Phone
Connectivity - usb cable
im not a genius or anything but i have nokia pc suite and i cant drag files to my phone either. i usually just plug the memory card into the computer and it comes up as a memory card with the images and video clips folders etc. im pretty sure its faster than the usb cable. you could also buy a usb infrared thing but they are very slow to transfer files. so if you really want to use your usb cable then this question wouldnt've helpd. thanks. Louis
Dec 24, 2007 | Nokia 6288 Cellular Phone
Nokia 6288
restore handset and reinsert sim then try...else problem with usb slots to the display connector....get it repaired frm nokia care center.
Nov 10, 2007 | Nokia 6288 Cellular Phone
Nokia 6288 - received an SMS, phone screen went blank
This issue can also be resolved simply by removing the batteries first, then remove your SD memory card, clean the SD card up with an eraser on it's gold/copper contacts, clean it and replace battery on the phone and turn it on. It would turn on, and then you can put the memory card back in. It is a common 6288 bug.
Unless this suggestion works, then you can follow the reset codes given by gizmo above...
Nov 09, 2007 | Nokia 6288 Cellular Phone
Virus Problem Won't Turn on 6288
The operating system of the phone has corrupted because of the theme being not compatible or a virus problem. You will have to take the cell to the authorized company service to reload the flash of the cell.
Oct 28, 2007 | Nokia 6288 Cellular Phone
Nokia 6288 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
