Only blank sheets appear either printing or copying
After you changed the printhead, even full cartridges need some time to fill up the head. So just copy a newspaper, put in a normal sheet of paper, and tell the printer it is a Photo, with Photo paper. It then will press the most ink.
If one of the colours start, it could take a complete A4 photo, before all colours are coming through.
I assume you did install the new head correct and not something else was defect before you started to change the head anyway. Because when something else was defect in the first place, a new head won't change that.
SOURCE: Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
SOURCE: print head replacement lexmark t632
Hi Kmccue,
The Lexmark T632 is a laser printer. It does not have a printhead. Perhaps it is the toner cartridge you are talking about. Pull the cover open in the front and pull the cartridge out.
Rgds
S88
SOURCE: printing blank pages
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
SOURCE: How do I stow Lexmark Impact S305 Control Panel?
find a tight plastic locking clip on the underside of the control panel. It may be at the top middle edge on the underside. Give it a very firm upwards press and it should unlock the control panel section.
