Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Tv won't change channel
Tv stays on channel 2 when i try to change the channel it says no input available,and i cant get the menu screen to come up.what do i do
  • 89 Answers
Did you hook the tv up to the converter box or did you not add channels?
Posted on Aug 05, 2009
    Master:
  • 505 Answers
How is the TV connected? make sure all the channels are configured properly and the correct input is selected
Posted on Jul 03, 2009
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
I cant hook up the red,white, and yellow wires to my magnavox tv
If you mean that the TV doesn't have a set of composite video/audio jacks, then you need a converter for the inputs on the TV. (Most likely you need a video converter (RF modulator) that converts the game console composite video to RF (coax) and set the TV to channel 3 or 4 usually. RF modulators are available from stores like Radio Shack for $30.)
If you have a TV with a composite video input and can't get the game console to view, then there is a different problem. First try new cables. Switch your input as needed for both the TV and the game system. This will depend on the TV and if you have the original remote/unlocked front panel buttons on the TV or a substitute remote that maintains all of the features of the original remote. On some TVs you can cycle through to the A/V inputs by increasing (or decreasing) the channels until you are between channel 2 and the highest available channel. (This doesn't always work if the TV has been programmed to skip channels that previously had no signal.) Otherwise look for a Source or Input button on the remote or TV (or an OSD menu (sub menu) that lets you change the source).
I hope this helps.
Aug 10, 2010 | Video Game Consoles & Games
I need to find out what channel my tv needs to be on
Try the input button on the TV remote it should only allow you to change to the inputs available.
Jan 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TC-32LX85 only stay on 5 minutes.
Just found a solution to this problem (conveniently hidden on unlucky page 13 of the user manual). This means that your TV is in store mode... it refreshes every so often and changes to the different inputs to show store viewers the quality of different inputs.
First, go to Menu - Setup - Advanced Setup and make sure that the "Auto power on" is set to "No." Turn the TV off and unplug it. Plug it back in. Press and HOLD the power button on the TV (not the remote). Hold for 2-3 seconds or so... you'll hear a few clicks. Release the button, then press it. The first thing that pops up should be, "Select viewing environment." Make sure you select "Home." Continue with setup from there.
Voila!
-Zach-
Aug 22, 2008 | Televison & Video
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
814 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
