Question about IBM ThinkPad T22 2647 Notebook
No audio on my laptop
I reformatted my laptop and after the process the audio is no longer working, no sound is coming out from the speakers,i checked on the device manager and under other devices option everything has a yellow question mark,how do i fix this? my laptop is a thinkpad t22 2647-8eg os is an xp and it is running on a sp3,i need help on this been trying to fix the problem myself for a week already. thanks in advance
    Master:
  • 505 Answers
You have to install the sound driver. If you have the drivers and utilities CD you will find the drivers there or else go to the manufacturers website and download the drivers from there
Posted on Jul 03, 2009
I reformatted my IBM laptop, after everything set up there's no sound or i cant play music
once you have reformatted and reinstalled your operating sytem you have to set up the sound system again
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 05, 2011 | IBM ThinkPad Soundcard
My laptop speaker is not working! it started not working only after i reformat my laptop ..
Surely you do not have sound drivers installed on your computer. Google your computer model followed by "sound driver" and over the results, enter manufacturer's official website. Download the sound driver, intall it, and check the sound operation.
Regards, MaTi_FleSh
Jul 03, 2011 | Computers & Internet
I recently had to reformat my computer back to factory standards. I had the Logitech Laptop Speakers Z205 b4 this & they worked.After i reformatted now i only get volume out of my laptop built in...
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Mar 31, 2011 | Logitech Laptop Speaker Z205 2 Speakers
No audio/sound coming from built-in speakers after reformat. might need to reinstall driver.
Check the mute button on the keypad.
You may go to ControlPanel - Sound.
Under Sounds tab, test if it responds.
If you have installed only the OS (Windows), then you are right, you also need to install the audio driver for the motherboard.
Go to motherbd manufacturer's website, put the model#, and download the audio driver.
(or just open Google, type ur laptop's model, then type audio driver).
If you got any recovery dvd alongwith this laptop, use it instead.
It should have everything in it : OS + all the drivers.
Nov 06, 2010 | Computers & Internet
My laptop is year and half old and couple of days back suddenly my laptop's speakers stopped working . i tried all option in the laptop to fix it .its not working.please help.
Steps to be followed:
1. check whether audio driver is installed properly ? if not install audio driver & check
2. check audio setting in control panel & confirm
3. connect external speaker in laptop and check whether sound is coming? if sound is coming then ur laptop internal speaker need replacement
4. if there is no sound in external speaker then need to check ur motherboard or sound card.
All the best.
Aug 16, 2010 | Computers & Internet
XP laptop no longer recognizes any USB speakers, and internal speakers dont work. USB speakers do not appear in the audio controls. the only 'device' listed under Sound Playback is SoundMax Digital Audio,...
Nothing wrong with your USB ports. MagicJack has changed your audio and driver settings so it can use the sound system for phone calls. The changes exist whether the Jack device in plugged in or not.
You can confirm the problem by uninstalling MagicJack and reinstalling your sound drivers. Should fix the problem.
You'll probably need to contact the maker of the MagicJack device for a workaround. Might be something specific to your laptop/operating system.
Nov 13, 2009 | Toshiba Satellite M45-S2653 Notebook
USB ports do not work. No sound from Speakers
Hi I am Vortash ... .. if you have your audio drivers re-install them after you Check the sound settings in advanced and make sure the speakers are not disabled .. As for the usb ports check in device manager that the usb is installed and enabled and that your drivers are working if not update if it asks search web say yes if your on the web where you are and get the latest ones ... hope this helps Vortash
May 02, 2009 | Dell Inspiron 1100 Notebook
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
Crap sound, subwoofer no longer working
Guys try to reinstall your audio drivers, because i had the same exact problem, so find out what sounds card you have and go on their website and download the latest sound card driver
Mar 03, 2008 | Logitech X-230 Computer Speakers
IBM ThinkPad T22 2647 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
