Question about Hotpoint FFU00 Side by Side Refrigerator
Freezer has a wering sound on and on
Finally shuts off after 5 hrs. someome told me it might be the fan defroster fan inside the freezer. can i get one shipped to me?
  • Hotpoint Master
  • 4,655 Answers
This problem can range from a variety of things.Defrost control, defrost element/thermostat, defective fan motors, defective start relays and even more. The refrigerator should cycle into defrost every 8 to 10 hours. The fact that yours is making a noise and then stopping every 5 hours makes me think that you either have a defective fan motor condenser or evaporator or a defective start relay. Now if the freezer shows signs of frosting over this will change the whole solution. Give me more information on where and what sounds are coming from. Clean the condenser coil beneath the fridge. and examine the fan and see if top of compressor is too hot to touch, Let me know, Sea Breeze
Posted on Jul 03, 2009
The upper part of freezer is warm and the lower part is cold. what gives?
sounds like a defrost problem.. but be sure the freezer fan is running.. if the fan is running I would look at it being a defrost issue.... I hope this helped........ ken
Sep 29, 2014 | Refrigerators
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Why has my fridge stopped working but my freezer still works its Hotpoint mistral plus
Possible that there is block on the air passage from the freezer fan which can be due to frost or failure of the fan.You need to check if there is free flow from the fan, also the setting of the fridge temperature.
Nov 26, 2011 | Refrigerators
Freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Nov 25, 2009 | GE Adora DSS25KSTSS Stainless Steel Side...
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Defrost problem
No there is nothing to reset. It could be one of three things. Let the unit defrost completley. Take the same back pannel off. Check to see if your heater at the bottom is discolored or if you can see thats its broken inside. The next thing it could be is the limith switch which is located on the top of the evaperator. If both those seem fine you can go to the back of the unit and check the main control board. Most of the time its the heater though.
Good Luck
Jul 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Refrigerator and freezer not cold enough
Can you find the make and model numbers for me. The model is usually located inside the fresh food section door near floor. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Refrigerators
My freezer works fine but the refrigerator does not
check to see if your fan in frezzer is working if not u need fan if it. is see if there is frost on back wall of frezzer if there is u have a defrost problem .u can unplug and let thaw with draw open for 4 or 5 hrs will work fine till u get service ther if it is defrost
Mar 18, 2009 | Maytag MFD2560HES Bottom Freezer French...
GE Side by Side Not cooling/freezing
sounds like defrost problem. remove back lower panel in freezer. defrost all ice on coils, this will fix problem temporaily. I`m looking for the tech sheet to test system.
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint FFU00 Side by Side Refrigerator Logo
99 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
