Question about LG W1941S-PF Monitor
Need instructions on installing a lg w1941s monitor
I have a CRT monitor and have just got this lg model and would like to know the best way to install the new one G Jarratt
    Master:
  • 505 Answers
Just connect the TV to your computer using S video / HDMI or VGA cable. Also your display card should support the same. You will see the TV listed there
Posted on Jul 03, 2009
LG LCD IC damaged
it would be cheaper to just replace the screen. The cost of the IC and equipment to install it again would cost way more and also would require to program the chip and the codes are almost impossible to get
Sep 08, 2013 | LG Computers & Internet
Screen resolution is not fitted in down, i am unable to see the taskbar. I have tried more and more to set the screen but its not fitted yet.
hi..
LG W1941S-PF Monitor is a 19" TFT monitor with max resolution of 1366x768. So there should not be any problems with viewing . This monitor incorporates an auto fitting option which will set common resolutions evenly and nicely.
look for a button named "AUTO" on monitor panel and press it. It will fill screen automatically..
Mar 18, 2011 | LG W1941S-PF Monitor
I am using an LG W1941S PF monitor, after using 2 yrs, the LCD Panel had to be changed. Previous optimal resolution was 1360x768 but after LCD replacement, it has changed to 1280x768. There are many more...
Hi, I would check with the repair shop that replaced the panel as it should register as 1366x768. The repair shop could have put in a different resolution panel and controller that didn't match the original and that's why you aren't seeing the 1366x768 option. Also worth noting is that often you can buy a new monitor of the same or better for less than what it costs to have it repaired. For example you can get a 20" scepter 1600x900 monitor from Amazon for $70.
Dec 26, 2017 | LG W1941S-PF Monitor
On my monitor W1941S half of area (left side) changed all colours to darker then right side (which is o.k.), What is the problem? Thank you.
Press f-Engine button (it is on the right side of MENU button), select your desired setting, if it doesn't help, select the "X" (none) mode - the half dark screen will reset to full screen OK mode.
Jan 08, 2011 | LG W1941S-PF Monitor
I am having LG W1941S lcd monitor it automaticallyturns on and of
First place to look will be the caps in the power supply section, look for caps with bulging top, post back what you see so we can guide you further, failed caps are common problems, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 07, 2010 | LG W1941S-PF Monitor
I need the driver for LG Flatron W1941S Monitor
http://ar.lgservice.com/gcsc/b2c/hpi/main where you have to complete the model number (type 1941 only) and obtain the same zip file. Good luck! Attached Files zip.gif W1941.zip (6.8 KB, 519 views)
Jul 08, 2009 | Computers & Internet
I need the elctronic layout of monitor lg flatron 775ft
TYPE THE FOLLOWING INFORMATION
WWW.MFG NAME.COM/SERVICE
WWW.SCHEMITICS LG FLATRON 775FT [WHITE] 17" CRT MONITOR
ENTER
LG FLATRON 775FT 17" CRT MONITOR SCHEMITICS
OR
LAYOUT
ENTER
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
LG W1941S-PF Monitor Logo
285 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
