Question about Daewoo DVG-8500N DVD Player
DVD/HDD machine freezes and needs to be reset each time it's used
Good day,
I have a Daewoo HDD/DVD Recorder DH-6111D and have been using it for almost 1 1/2 years. It sometimes used to freeze up - even blocking any tv signal - once swithed on and the only way to get any response is to either unplug / reset the machine by holding in the dvd/hdd button for more than 5secs. Just to clarify: the lights go on, the fan turns but the machine does not respond to any input from the remote or by pressing any buttons on the machine. Recently it has been freezing up every time we use the machine, sometimes requiring up to 3 resets. It also does that when we set the timer for recording resulting in a loss of a planned recording. Is there any way to almost 'format the hard disk' completely to factory default?
Thank you.
    Sergeant:
    Champion:
  • 245 Answers
Yes there is .......u can reset to factory setting.....u will find it in ur Manuel booklet/////
if not go in touch with daewoo service depaartment and u will get help from them
cheers hope all works out for u.......
Posted on Jul 03, 2009
I am trying to repair a Daewoo DVD Recorder DH-6111P and have need of a replacement hard disk drive 80Gb PATA. I have Seagate drives in stock. How do I prepare one for use in the machine?
hi, in this page show how backup software and very useful for drive replace
http://vladikuz72.narod.ru/DAEWOO_DHR/firmware_backup/how_to_backup.htm6
The major problems are often drive support and getting the drives formatted for use. It typically can't be done using a Windows PC. Some units will auto format the HDD once it is installed (assuming a recognized and supported HDD is used) and others have data stored on the drive which must be moved to the new drive before it can be used. I've never worked with any Daewoo models and aside from Tivo units try to avoid it as it isn't typically worth the headaches.
  1. Plug the HDD from the Daewoo in your PC.
  2. Download this program: https://rapidshare.com/files/2092882716/DMDE.7z2
  3. Open the program and select the appropriate physical drive from Daewoo (Disk Management)
  4. Click: Mode> Hexadecimal. Then click Tools> Copy Sectors
    Start sector: 0
    End sector: 19999
    Destination: Click "File"
    And save where you can find it! It's probably 10MB.
  5. Click OK and after done, unplug the HDD
  6. Plugin you're new HDD and in the program click: Drive> Select Drive (you're new HDD)
  7. Again Hexadecimal mode! Look all the way down of the list. Find the number of the last block!
  8. Tools> Fill Sectors:
    Start sector: 0
    End sector: That you've searched for
    Hex: 00
    Click OK
    THIS MUST BE DONE, OTHERWISE IT WON'T WORK!!!!
  9. Now again Tools> Copy Sectors
    By source, select file and open the file you've saved in the beginning.
    Destination: Start sector: 0
    Click OK
  10. You're done!!
    Plug the new HDD in you're Daewoo product and if followed the steps.
    It will give you the Daewoo boot up logo and immediately it will pop-up say: "Formatting Hard Disk"
I have now a 750GB HDD in my Daewoo!!! :D:D
You have now the OS System (.BIN file) of Daewoo on your computer for future reasons.
user manual
http://tv.manualsonline.com/manuals/mfg/daewoo_electronics/dh6100p.html?p=1
Jul 09, 2017 | Seagate Computers & Internet
Magnavox MDR537H/F7 no power
Some surge protectors cut off all power, when they reach the surge protection limit in joules. Power strips have reset buttons to restore power. Try plugging it directly into the electrical wall socket. If it works, then purchase a new surge protector. The DVD recorder may have a internal fuse that has burned open.
Jun 03, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Magnavox MDR537H/F7 -- DEAD no power
There is usually an internal fuse in all audio/video equipment and it will normally be a 20mm glass one positioned near the power supply or somewher close on the circuit board. There may be more than one so have a good check around. Be sure to replace with the same type and rating, no sticking kitchen foil across it to short it out, this illegal and DANGEROUS.
I have a Daewoo DH 6111D HDD/DVD Recorder. I have recordered a program on HQ on the Hard Drive for 2.5 Hrs. The problem I have is that I cannot Dub this to a DVD disc because there is not enough space...
If you try to burn this on a single layer DVD disk then you will get this error message unless your DVD burn program can compress the video so it can fit on a single layer DVD disc.
OTHERWISE
You need to upgrade your burner to a dual layer burner and burn your video onto a dual layer DVD disc.
Sep 01, 2011 | Computers & Internet
I own a Daewoo DH-6100P DVD player/recorder and I am unable to get the set up menu to appear on the TV screen. The TV and DVD player are connected to a Sky Box. Can you help please? Keith Saunders
The model is DH-6100P, 80gb HDD crashed then formatted it. Now no start-up menu, stuck please help with solution or firmware file for re-install if possible.
Feb 28, 2011 | Daewoo Televison & Video
We have a Daewoo DC DVB-T HDD/DVD Recorder. We
menu--hdd playlist--ok -select recording--select play then scroll down to dubbing--ok --add or scroll down to start dub.
Its not a problem
Dec 07, 2009 | Daewoo Televison & Video
Dvb t vcr/dvd recorder drvt 43 freezes after being plugged in
I have the same problem. Telephoned Daewoo and they said that there was a download available that will fix it. Unfortunately, the contol keeps freezing so I can't do this. Therefore, I have contacted the retail supplier and they are sending a replacement and also letting me have relevant info to send the defect one back. Hope this helps.
Jan 25, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Daewoo DVR
Pls verify that the new HDD is set as "Master: Additionally, most DVRs have a built-in "Format" command/feature that will format the drive to the appropriate manner.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 12, 2008 | Televison & Video
Problems with Daewoo DH-6111D HDD/ DVD recorder
I checked in the instruction manual and found out that I had not "finalised: the DVDs that I had recorded. So I reckon that this will solve my problem.
Feb 21, 2008 | Televison & Video
Daewoo dh-6111d DVD/HDD player/recorder. regional codes unlock
Report your Video shop to RiSA. They should legally only carry zone 2 DVD's as a rental copy and a sale copy has two different licenses of use. If they have zone 1 DVD's it means they are bypassing the local supply chain (ie getting it outside South Africa) and damaging the industry as a whole.
Dec 22, 2007 | Daewoo DVG-8500N DVD Player
Daewoo DVG-8500N DVD Player Logo
268 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
