Question about Mitsubishi Televison & Video
Mitsubishi VS-50805 doesn't turn on. We had a brown out due to power lines being damaged by fallen trees and the tv went out a few minutes after other stuff did. now it won't turn on
    President:
  • Mitsubishi Master
  • 1,348 Answers
Check the fuses inside the tv .
Posted on Jul 03, 2009
I have audio but picture blacks out
You may have a bad ground on your vertical IC to begin with! Other repairs would include a bad ground on a coil or the horizontal transformer. The biggest problem is, Yes you have some bad grounds. Repair will be, to find the cracked rings underneath the boards and resolder. Take this note to your local TV Tech, this is your best defense in keeping the the repair cost down! Knowledge, in this case, is on your side now. Good Luck in your search!
Jul 03, 2010 | Mitsubishi VS-50805 50" Rear Projection...
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50805 HD 1080 Series
check the convergence ic's unplug the main convergence board plug then try the set again if the set comes on get a convergence kit here
http://www.tvrepairkits.com/xcart/home.php?partner=larry
May 16, 2010 | Televison & Video
I have a mitsubishi model vs-50805 projection tv and my picture has a 3d effect u can see the letters in the menu in 3 colors
the problem with this unit is in the convergence ic's need to replace and check for bad resistors and pico fuses in the circuit
Jan 25, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Distorted picture,After power loss
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS 50805/60805 blue/yellow shadows on screen
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple do the above
Aug 17, 2008 | Mitsubishi WS-55807 TV
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection TV
1. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET
Aug 21, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-50805 Service Mode
Sounds like you gotta call that guy back or report him for damaging your set.
Sep 13, 2006 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi vs-50805
You said you checked the convergence ICs and they're okay - WHAT did you check? Check temperature. Also, try rapping on the heat sink they're mounted on, see if that shuts it down or causes flickers in picture. If those provide no further insight, your problem is bad capacitors on the power supply/waveform generator/deflection board, you will need ESR equipment to check them and good soldering skills to replace. Unit will require in-shop service. A repair bill over $250 is a swindle - we did one for half of that last week.
Jul 12, 2006 | Mitsubishi VS-50805 50" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
