Question about Sanyo Audio Players & Recorders
Factory reset when turned off.
My Sanyo stero keeps resetting to factory defaults when I turn it off. When I turn it back on, all preset radio stations are gone, and the 5 disk CD tray spins a full revolution. It didn't used to do this. I opened it up and looked inside for anything that jumped out at me as being a battery that I could replace, but couldn't see anything- though I wasn't sure what to look for.
The stereo is is about 10 years old, but it has special meaning to me so I don't want to replace it. Plus, other than this problem, it's a good quality unit. Any tips or help would be amazing! Thanks.
It's a Sanyo GCD 2000U CD Shelf Audio System
  • Samkarn Nov 10, 2007
    Here's a photo of the system.
techman
  • 3130 Answers
SOURCE: CD Player Tray Spins Continuously With or Without Disk
Yuo didnt mention if it was used or new,. If it was new I wouldnt mess with the unit and take it in under warranty, as there is no quicky fix for this one. Its going to turn out to be a problem with the disc motor servo circuit or the microprocessor. Good Luck
Posted on Aug 06, 2006
SOURCE: Erratic CD tray behavior on SONY MHC-881 Shelf system
change cd head
Posted on Nov 27, 2007
zair
  • 82 Answers
SOURCE: How do you reset the 5 cd disk?
Try this to rest unit.With cd selected press and hold 'Stop' for about 5 sec. keep holding then press and hold 'skip FF' for about 5 more sec. Take off power then unplug unit, then power back on. A line shows across the screen if it works.
Posted on Dec 05, 2007
sanjin
  • 56 Answers
SOURCE: broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Posted on Feb 19, 2008
SOURCE: CD player fails to read CDs
Hi Everyone !
We got the same problem two month ago and we fix it. The problem is drying lubricate oil from elector motor which spin the cd disk. You need to open top cover its 5 screw , 4 an sides and 1 on back. Then you see black cd changer in side. You need to open top cover of cd changer by unlock plastic clips and slide cover. Under cd holder you can fined elector motor that spin cd. You just need two drops of lubricate oil on top bearing at electromotor. My works fine right now .
Good luck.
Posted on May 23, 2008
How do u get parental passcode
Try a reset
To restore the TV to its factory default settings:
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight System
and press OK. The SYSTEM menu is displayed.
3. Highlight Reset & Admin and press OK. The RESET & ADMIN
menu is displayed.
4. Highlight Reset TV to Factory Defaults and press OK.
5. If you have changed the default parental control PIN, enter it
now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults."
6. Highlight Reset and press OK.
7. Wait for the TV to turn off. The TV will turn back on shortly.
If you have not set a PIN, enter the
default, 0000
Feb 14, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
How do i reset the computer on a 2003 Ford F150 7700 series
Resetting a computer only resets the KAM (keep alive memory), back to factory defaults. This is what the computer learns from your driving habits. What's the problem? why do you want to reset the computer? If the check engine light is on, it will only go off if the problem was fixed. If you don't have a scanner to turn it off, it will go off after several key on and off's. Again, if the problem was fixed. Just a note, it takes 30 minutes to reset the KAM.
Feb 27, 2015 | Ford Cars & Trucks
We just purchased the Motorola RDU 4100 radios. 8 of them to mix in with 4 others of the same model number. radios were working fine up until recently when 3 of the radios are now broadcasting the same...
Reset to Factory Defaults (Pg. 34)
Reset to Factory Defaults will set back all radio
features to the original factory default settings.
To do so, press PTT, SB2 and SB1
simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
Aug 15, 2011 | Motorola RDU4100 Two Way Radio
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Receiver will not remember preset channels anymore
Try a factory reset
Menu -> Factory Defaults
If those don't work power of your radio and press:
2-1-1 + Push down Tuning Wheel
This will erase all of your presets.
Dec 27, 2010 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
My battery went dead on my honda, the stero code comes up where cani find it?
The reset code for your radio is located in the glove compartment. There should be a small sticker on the inside of the compartment door, usually near the left side. The sticker has two sets of numbers printed on it. The number set with five digits is your reset code. Use the radio preset buttons to input the code. If done correctly, the radio should come on immediately and show the factory default presets.
Positive feedback is greatly appreciated.
God Bless and good luck.
Dec 05, 2010 | 2007 Honda Accord Sedan
Have ajustments all screwed up
If you can’t resolve the issue yourself, try resetting
the AV receiver before contacting your Onkyo dealer.
To reset the AV receiver to its factory defaults,
turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. “Clear”
will appear on the display and the AV receiver will
enter Standby mode.
Note that resetting the AV receiver will delete your
radio presets and custom settings.
Feb 10, 2010 | Onkyo HT-S9100THX 7.1 Channel Receiver and...
Cd in car stereo won't eject. I have a 2005 Chrysler T&C van and there is a CD in my stero that won't eject. Any suggestions?
Try turning the radio off and disconnecting the battery for 2 min then reconnect the battery and turn on the radio. This may reset the radio to default so you can eject the CD and reset your station preset and clock. make sure the radio is off before disconnecting the battery or your going to be prompt to program a radio code. Good luck and this should work.
Jan 02, 2010 | 2005 Chrysler Town & Country
Roady xt
i figured it out with help from a delphi service rep.! you need to go into the menu and reset to factory default.this will erase everything you have changed from the factory settings,but once done you can reprogram your settings and they will stay. step 1-enter menu step 2-reset factory default settings step 3-reprogram your preset stations,FM freq. colors etc. step 4-use power button on the roady to turn it off.once the roady shuts down turn it back on with the power button. step 4-now you should be able to turn the key off without erasing your presets.
Apr 25, 2008 | Delphi Roady XT XM Radio Receiver
75 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
