Question about Mitsubishi WS-48613 48" Rear Projection Television
No power on projection tv - Mitsubishi WS-48613 48" Rear Projection Television
  • 1,694 Answers
Re: No power on projection tv
Is it blinking the power indicator? Confirm model #.......
Probable bad DM module = repairable by qualified Mits. tech....
Posted on Nov 10, 2007
0 characters
3 Points
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
When i turn power on the power light comes on but no picture the lamp light comes on then starts blinking?
The tv projection lamp has not been replaced in this tv like 1 1/2 or 2 years?The tv been on an watches tv like 4 or 5 hours a day?Yes,than the projection lamp life is over.The tv require a new projection lamp.
Oct 12, 2010 | JVC HD-52G886 52" Rear Projection HDTV
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
No power to a 65" Projection Mitsibishi.
The inputs may have to be re-soldered this is a common issue with projection screens
Oct 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
Dead TV
hi there, this is a blown bulb. just replace the bad bulb and your TV will power up once more.
Mar 06, 2009 | Toshiba 53H71 53 in. Rear Projection...
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
