Home | Blenders | Krups blender blade sto...
Blenders
Problem for Blenders
Generic problem for all Blenders
Krups blender blade stops
By kuzikan on Jul 03, 2009
I have a Krups Power Xtreme VI blender that refuses to blend. While making a daquiri one night my sister noticed a burnt rubber smell so she unplugged the blender and took the jar off. The small grey rubber gear that turns the blade had stripped itself almost completely groove free. I went online and found a replacement gear and a replacement blade. I thought it couldn't hurt while I had it apart right?
As soon as the parts came in the mail I went online and got directions on how to replace the gear and the blade. After I put the blender back together I plugged it in and saw that everything was spinning as it should be. Later that night I had to try it out so I threw mix and ice in to make a drink and the blad stopped spinning. It would spin for a second then stop. I emptied the jar and turned it back on and the blade spun just fine. The gear is not stripped at all and I hear the motor running just fine. But everytime I put anything in the jar the blades stop spinning. I wonder if there is something else wrong that caused the gear to get stripped in the first place. Any ideas at all I would really appreciate. I'm dying for a drink!!
Comments:
Jul 06, 2009
- Okay, I was trying to follow this advice and take the gear back off and recheck everything when I noticed another symptom. I inserted a small screwdriver into the bottom to hold the shaft still while I turned the gear just as I had to remove the old one and put the new one on. The gear continues to move but the shaft stops. The strange thing is that the shaft moves along with the gear until any resistance is applied. Just to make sure I wasn't seeing things, I plugged the blender in and while holding the gear with a towel, turned it on. The gear wasn't moving but the shaft was. So here's the situation. The bottom cannot be taken off until the gear is removed. I cannot remove the gear because I can't keep it from turning. I am open to any ideas at this point because right now it is useless to me.
Best Solution
posted on Jul 03, 2009
Helpful)
falter
Rank: Wiz
Rating: 76%, 131 votes
well it looks to me there is some thing not tight enough connection to ur blade.....as u say it works when empty but when u put soemting in its stops....this means ur blade is not tight on the shaft to the motor......or u may have done something wrong when u had the blender open........recheck ur work and make sure its tight,,,,,
if so u will have ur ice cold drink....cheers i hope so for ur shake
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Blenders
Questions and Unsolved Problems for Blenders
Answer
pour spout broken on back to basic sp smoothie 600
Answer
I'm willing to pay up to 100$ for an efficient blender.Every year I make my own pesto sauce(I puree... (More)
Answer
The blades are frozen. I have tried soaking in hot water and WD40. Any other solutions? Can this... (More)
Answer
Need valve mechanism for my Back to Basics Smoothie Splash. It is black.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Blenders:
Top Blender Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
