Question about Dryers
Dryer?NO Heat. KENMORE I just hooked up the All In One, after completely cleaning all interior surfaces of lint?from years of neglect. The unit is sound, and washed two loads efficiently. The load of lightweight items (t-shirts/pyjamas)?took forever to dry. The vent output was warm, the lint collected on the screen, normally. The items in the dryer were never HOT when I checked the load; not even a little.
    Problem Solver:
  • 9 Answers
I believe there is more than one heating elements in these and it sound like theres a bad one or all of them if you can access the interior i would check the elements its usualy obvious if its bad they will have a break in the wire or the ceramic prong
Posted on Jul 03, 2009
Samsung DV448ae electric dryer. Sensor mode not working replaced the moisture sensor with not change. What could it be? Dryer is heating.
I may be misinterpreting your complaint, but I think your stating that the dryer doesn't dry properly. If so, the first thing I would check is to see if the exhaust duct is clogged with lint (they need to be cleaned out once a year or the ability of the dryer to dry clothes properly diminishes to zero).
What I do is, I disconnect the duct at the back of the dryer and connect a shop vac to the duct. (The kit comes with a shop vac hose-to-duct adaptor). Then I go outside, and using an cordless drill, attach a special duct cleaning brush to the drill (the kit comes with several extension wands to increase its length) and run the brush through the outside cover and down into the duct. The drill spins the brush, completely cleaning the interior of the duct. You can buy the brush at any home center, I bought mine at Menards.
Example: Amazon com Deflecto Dryer Duct Cleaning Kit Extends Up To 12 Home...
After I'm done, I'll also use the extension pipe on the shop vac and push it up into the dryer itself to clean out that part of the exhaust.
If you neglect to clean the duct, the dryer will eventually take forever to dry clothes and they will still come out damp.
Jun 11, 2017 | Samsung Dryers
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Can my heat sensor be replaced by myself or do I need to call a technician?
It depends on if it is a heat sensor or a thermal fuse or even something else.
I would need to know what your dryer is "doing" or "not doing"
If you are sure of the part already; sure you can do it...but...
I recomend you:
1) Unplug it
2) Clean interior of all lint
3) Clean lint out of exhaust chute
4) Check for any breakage or parts laying on interior bottom
5) be careful when restarting to test as follows:
A) stay clear from dryer
B0be ready to shut it off quickly in the event of a problem
Good luck,
Vinnie
Aug 21, 2010 | Kenmore 500 6952 Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Replaced thermal fuse ,ran cycle all the way than died again.Have had to replace fuse in past would usually get 9 months out of it .Replaced it dryer ran fine but after cycle completed dryer was dead...
Have you cleaned the lint out of the airways and the heat exchanger area? The lint filter traps most of the lint but not all, the airways and especially the area where the heating element is still fills up with lint. To get it out, you'll have to take the back off the dryer and open up the enclosure for the heating element and vacuum it out. The lint clogs the airway, which restricts the airflow, which lets the heating element get too hot, which is why the thermal fuse shuts it off. Otherwise, it would catch fire (and in some cases, still does). It should be good for another few years when you get the lint out. Good luck.
Aug 16, 2009 | Kenmore Dryers
Kenmore dryer starts, then stops. Heated motor smell
First CLEAN out the lint, not just in the mesh screen, but also by opening up the dryer to check for lint around the motor, and the manifold that connects from the drum to the outlet tube. Open up the manifold, carefully, remove lint, and REPLACE the heat sensor/temperature thermocouple that is on the outside, and has a protruding point into the manifold ($20 or less). If the drum spins when you start the cycle, it is NOT the motor! The burning smell is probably LINT that stuffed into the outlet pipe and manifold.
I have cleaned the outlet tube, manifold, and areas under/around the drum for my dryer, and my rental properties and "fixed" the problem. If it still turns off, then get the correct replacement sensors and replace them. DO NOT open the heating element. The wires inside are fragile.
Sep 08, 2017 | Dryers
Back outside wall of dryer is burning
hi. thanks for the question . pull dryer away from the wall. remove venting .clean venting to the outside. remove back panel. clean all lint first. cut power to te dryer . try again thanks the appliance doc. positive feed back .thanks the appliance doc
Oct 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore All in One?Dryer Heat Minimal?Excessive Dry time
be sure vent to outside is not plugged or partially block be sure vet tube in back is not compressed flat or folded basically be sure you have good air flow to outside to take the moisture to the outside away from the clothes
Jun 06, 2008 | Kenmore 45081 Front Load Washer / Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
