Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Having a few problems with our brother
For some reason it keeps on cleaning all the time. it now wont print in black. and the colors are on the light side. the printer is only new last month
    President:
  • 2,306 Answers
Brother gives you a 1 year warranty, I would take it in for service.
Posted on Jul 03, 2009
  • samanthas777 Jun 21, 2011
    try manually doing a head clean it should be under ink managment do about 3 x of them should solve if not might be blocked print head
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
Brother 490cw no red and no yellow print after a few time cleanning still not working blue and black work fine
You need to have the print head replaced. Brother is covering the cost to repair this problem if you call 1-877-276-8437 and tell them you are missing 2 colors on print outs.
Jun 09, 2011 | Brother MFC 490cw Color Inkjet...
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
I cant print in color
For reasons known only to Brother you are unable to print ANYTHING if you are out of any color of ink. If you are out of black and need to only print in color it WILL NOT work
Feb 23, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
I have a brother mfc 3240C. I have changed the
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Apr 23, 2009 | Brother Office Equipment & Supplies
I replaced all cartridges and it wont print black
IF YOU ARE USING REFILLS YOU HAVE DAMAGED THE PRINT HEAD,
Dec 17, 2008 | Brother MFC 240C All-In-One InkJet Printer
Black won't print
I have this same model printer and had this same problem. I solved it by running the cleaning cycle repeatedly (30 times or more). It nealy drained the black cartridge, but they're cheap compared to a new printer ($100 for the mfc240c that replaced it). Press the ink button to the left of the display. Select "test print" and "print quality from the menus, then hit print. After printing, the display will ask if quality is ok. Press 2 for no. It will ask if the black was ok, press 2 for no, if the color looks ok, then press 1 when it asks if color is ok, then press 1 when it asks to start cleaning. In a minute or so, it will beep and tell you to press start. Once the sheet prints again, repeat the same sequence. I didn't even wait for the display, I would just press 2,2,1,1, each time it printed. At first the black section was blank, the one dash appeared, then two or three. I gradually gained on it until I had most of them working again, then let it set overnight and ran a few more cycles the next day and it finally all started working.
Jun 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Balck ink not working
machine needs to go into a cleaning process once you installed new cartridges to identify that there is a new one placed there.it will need 5 cleanings to do that.if you are using refillables or generic cart,then it wont properly mix up with the others causing that specific color not to print
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
201 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
