What do I do to start the universal remote to see the tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
SOURCE: Emerson TV- Sentry Really Big Universal Remote
www.remotecodelist.com .........................................T.
SOURCE: Sentry really big universal remote
Request Information
by sooky, posted on Jan 12, 2008
Does anyone know the codes for a Vizio LCD TV?
The code to use is LG 1292...these other two have worked for others as well...0178 or 0030. good luck
Ya it does work with the codes given.. Just make sure you are close to the tv or product you are wanting to program -- other equipment can interfer ... hold search code button down until it stays on then press tv/sat or what ever u want to program then put in the code then power button, item should shut off-- if it doesn't work then try the next code for the brand of tv/sat/vcr u have.. here is the web site with the manual on it..3 different models of this remote just select the one u have from the list on the left.
http://www.sentryindustries.com/category/remotes/remotes_rmc10.asp
SOURCE: NEED the emerson tv codes for sentry really big universal remote!
Remote code for Emerson TV, as per the updated manual (link provided below)
004 009 014 023 024 025 035 036 037 038 039 040 041 042 043 045 049 051 053 116 135 147 155 177 179 189 198
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
Cheers and best of luck!
