Question about Intel DG965RY Motherboard
Intel DG965RY CPU Overheating
My mobo is showing error message of cpu overheating, at first it will boot up and will show desktop after 5 minutes it will shotdown then i will press power it will boot but will show above mentioned error and eill shutdown again, i have checked the cooling fan and its working fine, im using an intel pentium D 3.00ghs, kingston 2gb ram, not overclocked, help please, tnx
  • 784 Answers
Check the clamp of the cooling fan. If the clamp is not engaged, heat sink didn't take the heat away from the micro processor causing CPU over heating.
Posted on Jul 03, 2009
    Problem Solver:
  • 17 Answers
It may be because , your heatsink is not fixed properly, to the chips aluminium base due to loose clamping, or it may be due to lack of thermal grease(a chemical compound meant to libricate the heat transfer between the cpu and heat sink) Most probably, the second case would solve it, if not your heatsink is not fixed tightly to the base(cpu)
Posted on Aug 28, 2009
HCL INFINITI L A380 TRU PC doesnot boot.Gives error about EFI. Initially we get two beeps and after about 5 minutes gives error message and it goes to bios setup
Try just one stick of memory, then another, most likely you have bad RAM.
Can be a destroyed CPU from overheating as well.
Mar 17, 2015 | Intel Computers & Internet
No booting broblem
I guess the CPU isnt completely ruled out. It might have a bad pin, or your mobo might have a bad socket that got fixed when you jiggled it..but that would be a big problem, and you'll have to take your cpu and look closely at it and the mobo to look for defects.
If its overheating it wouldnt do it immediately. It would get past POST and problem overheat at "starting windows". and if it did that most mobo's will display an error message before POSTing that says it had to shut down your system to prevent overheating.
Plus you also have a decent cpu cooler, so even if you did a terrible job putting on the thermal paste it shouldnt cause your cpu to overheat, unless you have doing a huge overclock, then it might happen.
Are you overclocked right now? have you tried setting everything back to stock speeds and booting like that?
I can help you via for fixing computer problem on internet via teamviewer in 1 hour
Email besumitbe@gmail.com or call me 9004108811
or refer below site 2 get solution
Source(s):
http://goo.gl/m35bL
Jul 12, 2013 | Acer Aspire 5742G
Building desktop: no beeps, no video The mobo LED are on, fan is running but getting no signal to monitor. I've tested the video card in another pc and confirmed working. The only time the mobo beeps...
If the cpu was bad- nothing would turn on--be sure the cable is good-- also be sure the VGA is enabled in the bios- since you cant see the video you have to reset the cmos setting--unplug the unit and remove the cmos battery-reinstall after one minute and check for video
Apr 10, 2010 | Intel Desktop Board D850MD Motherboard
Screen freezes and shows lots of lines - must restart everything. This is happening more often.
This can be memory, CPU, Hard drive, or graphics card, or overheating.
To check the memory, hdd, and cpu you can download the ultimate boot cd UBCD Burn it to a disc then boot to it. Use the utilities on it to test your components.
To check and track your temps you can download HWMonitor keep this running until it crashes. Once it does, reboot then open it again. The program will show you the max that the cpu and gpu reached in temp. gpu ovr 60C is usually starting to overheat. CPU over 50-60C (unless its a core 2 duo or quad then its 80C) is overheating.
To help solve overheating buy a cooling pad and have the thermal paste/pads replaced on the cpu and gpu.
If the problem persists then there is a big possibility that your gpu is heating up to much and the motherboard is starting to lose the solder joints to it.
Feb 22, 2010 | Toshiba Satellite M300-ST3403 Notebook
Fail to boot
When you say boot do you mean POST?
Is it turning on at all?
What happens exactly when you press the power button?
Any beeps?
Open the case and remove everything except 1 RAM chip, the cpu, the cpu cooler. Hook up the monitor to the onboard graphics and try to boot again.
If it POSTs then you know that you have a problem with one of the pieces of hardware you removed, replace them 1 at a time until it fails to POST then you know which piece is defective.
If it still doesn't POST with everything removed, try a different RAM chip, if it still fails POST then you need to replace the motherboard.
Sep 16, 2009 | Intel DG965RY Motherboard
Same prob
This problem cannot be solved by anyone but a trained technician.
It will liklely requires one of the following repairs
1) new motherboard
2) new CPU
3) New CPU fan
4) new ATX power supply
This is my honest opinion after 100+ PM repairs personally.
best of luck,
Sagacious1
Aug 07, 2009 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
DG965RY boot problem
Hi niraj73
1. Remove the 1 Ram module from Slot B Channel 0.
2. See if problem is still there.
3. If not get another Ram module of same spec to fill up all 4 channels.
4 If error still there swap the removed Ram module with one of the Ram modules still installed. One of them might be faulty.
Regards
Go-Tech
Dec 14, 2008 | Intel DG965RY Motherboard
Computer hangs after 5 minutes from boot
Check the CPU fan (working) and heat sink as these over time clog up with fluff and dirt overheating CPU also check the rear of power supply for blocked ventilation holes
Jul 20, 2008 | Intel Pentium 4 1.7G, 1.7 GHz...
Intel DG965RY Motherboard Logo
497 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
