Question about Canon imageRUNNER 210S Copier
ERROR CODE E051
MY MACHINE SHOW ERROR CODE E051
HOW TO SOLVE THIS PROBLEM
  • Anonymous Mar 25, 2014
    having error codes on a set-up e080,e051,a50
  • chendoli srinivas
    chendoli srinivas Apr 16, 2014
    having error code on a set up E051
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Posted on Jul 03, 2009
  • manish thakker
    manish thakker Apr 15, 2014
    thanks a lot ronnie gregorio... you saved my day.
Error code e051
the horizontal registration home position detection mechanism has a fault
May 01, 2014 | Canon imageRUNNER 400 Printer
Canon ir 400
Sep 15, 2013 | Office Equipment & Supplies
How to solve E051 error please guide me...my machine is canon ir 400, problem started immediatly after starting the machine, i cleared the error by pressing addl fn+2+8&addl.fn but it didnt solve it....
This is failure of the horizontal registration motor. I've had to replace this motor and it's a very involved process. This is the very small motor located just above the paper pick-up assembly. If you're not a qualified tech then let a tech take care of it for you. You have to remove several covers, P/U assembly, and other things to get to it.
Jun 27, 2011 | Canon imageRUNNER 400S Copier
My machine shows E051 error how to solve this problem.. Switchmain power off & on E051 is the total display of my machine can u please give me a solution for this
E 051 IS PROBLEME OF REGISTRATION MOTOR SENSOR NOT OPERATING.THIS MAY BE DUE TO NON MOVEMENT OF SLIDER FOR FAILURE OF GEAR BREAKAGE OR OBSTRUCTION FOR ITS MOVEMENT.LOCATION AFTER OPENING RIGHT DOOR JUST BELOW FEEDER METAL PLATE.
Just got this used canon imagerunner 330s. It seemed to be working OK but now wont finish powering up and displays an E051 code. Can I clear or bypass this? What does this code indicate? Thanks, Keith
Error code E051 indicates there is a problem with the movable paper guides in the duplex unit. Check that the rear connector for the Duplex unit is clear of paper or toner
Feb 16, 2011 | Office Equipment & Supplies
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
Canon Gp 335 E051
E051 indicates that the side or horizontal registration sensor is not detected try to switch off/on the machine but if the same error code display again thereis a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 17, 2009 | Canon imageRUNNER 400S Copier
051 code showing in gp 405
Jul 09, 2009 | Canon imageRUNNER 400S Copier
My mich suddenly shows that E051 error can any one help me
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again there is a small motor that drive the sensor assy should be change.try to move the sensor manually by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 07, 2009 | Canon Office Equipment & Supplies
Canon IR400 copier
dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Jan 10, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Canon imageRUNNER 210S Copier Logo
1,973 people viewed this question
old marine
old marine
