Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
Hitachi 27GX01B pump-up Capacitor, ver...
By Reeves on Nov 10, 2007
I have a Hitachi 27GX01B bought it new in 2002, I now have all the telltale symptoms of a bad Pump up cap, I can provide schematics, if some body can point out the offending caps number {c????} I am fully aware of the 50Kv in there, and the danger involved, and know what im doing, just not too sure which cap it is. I have the PDF schematics, or they can be downloaded here, "Its in 3 parts" not sure why.
http://www.eserviceinfo.com/download.php?fileid=11779
Comments:
Nov 12, 2007
- Please could i get a little help, im really getting sick of these lines at the top of my screen, theres a complete circiut diagram that you can download or give me your e-mail and i could send it to you all I need to know is which cap in the vertical output circuit is known as the pump up capacitor, if you could tell me the number i.e. c401 thats the first one in the V/O circuit. Please I would really like to get this tv working, I find my eyes drawn to the lines and rollover effect, and its very annoying. Thank You in advance, c'mon guys somebody must know the answer :P
Nov 17, 2007
- "sigh"
If your not gonna help please just say so, so I can move on to another forum to seek assistance.
Nov 22, 2007
- heres a pic.... maybe you dont belive me, orr.....whatever anyway here it is.
Feb 12, 2008
- http://www.fixya.com/support/t266710-hitachi_27gx01b check here, I posted the problem 3 times, to be sure to get a quick response, if you check the link above you will see that I got some help, but i also had the service manual.
this may or may not help, it should be on the hot side of the board "be careful" and will be near a cluster of wires that go to the back of the picture tube, there is usually a small heatsink near the wires, there are a few small radial electrolytic caps in that area, I changed c454 which was right up against the heatsink, so was the most likely culprit, it had the values " 10mm 220uf 35v" so i went to "the source/radio shack" and picked up some cheap "12mm 220uf 50v" caps and used that to replace it, "you can use a higher voltage rated capacitor, in place of a lower V cap, BUT NOT THE OTHER WAY AROUND, been working flawlessly for a few months now, hope you find the problem, I will take a quick look see if i can find the service manual for your tv, if so i will post here.
L8r, Reeves Good Luck, and watch out for the flyback tranformer it can kill.
Same Problem
Feb 11, 2008
-   Phillips Model: 32PT5441/37 32" TV-   562793
Jan 14, 2008
-   reeves, did you find the solution?
-   a1xx
Solution #1
posted on Jun 30, 2008
Not Rated)
butterbean
Rank: Guide
Rating: 100%, 1 votes
yes i have fixed alot of tv's with same problem dried out caps by vertical ic.anywhere it gets warm or hot
Was this helpful?
Yes
No
Solution #2
posted on Feb 11, 2008
Not Rated)
562793
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem with a Phillips Model: 32PT5441/37
ISo far all I can find on this TV is the pump-up capacitor for the vertical output circuit may be bad but I can't find very much information on this model.
I do high end PC system builds and PC repair but have no expertise in TV repair so any help or a solution to my problem would be appreciated...
Thanks
JC
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
on a magnavox 42mf231d/37 plasma tv where is the ceramic capacitor 561k 2kv? i know it is next to... (More)
Answer
The image on the screen keeps blinking
Answer
Matsui 19dvdb19 TV Does not operate when left on standby for anytime, need to switch off for a while... (More)
Answer
I think my *enter* button on my television is stuck
Answer
no prende se apago de monento y olia a quemado
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
