Overheating on my Case 224. Anyone out there know what my problem my be????
You need a valve by SmaartCompare" in job or main i think your valve seats have come out on one or to valves take to shop and get checked before you run it again you could cuase damage
SOURCE: 1976 JD 214 lawn mower Kohler engine K321AQS
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
SOURCE: Electric PTO won't re-engage after running OK for a while
might be rust between the plates or you need to adjust the springs tenson there are 3 bolts on it
Testimonial: "Adjusting the gap worked. Old gap was .037". I adjusted it to .012"."
The "smell" is probably old coolant splashed in and around the engine, and radiator fins. When this residue gets hot it really stinks. Try rinsing out the engine compartment and radiator fins with low pressure water. It will go away.
OVERHEATING
Physically look in the radiator under the cap when cool, for coolant level, and check the valve in the cap for sticking. If air is present in the radiator it can't get out, and more coolant can't get in,(from the overflow). Either clean the cap or replace it and check that it is the CORRECT cap.
Radiator fins dirty, clean with a strong stream of water, not high pressure water.
Radiator clogged, have it boiled out, or replace.
Thermostat stuck open or shut, replace it.
Water pump worn out, can no longer move enough coolant, replace it.
Fan shroud broken or missing....
Electric Fan(s) not working, Check the fan, relay, fuse and engine temperature sensor's.
Belt driven fan, belt slipping, fan clutch is bad, fan blades have flattened out.
Air dam under front bumper is gone, loose, or broken. It actually has a purpose other than scraping on the driveway or curbs. It forces air up into and thru the condenser and radiator. If it's loose, airflow can actually push it out of place making it useless or blocking the airflow. Along with that, there may also be a plastic piece attached to the bottom of, and wraps up behind the bumper. If it's loose, airflow can actually push it out of place blocking the airflow. Simply reattach it with 4 or 5 screws.
Also, if the vehicle has A/C and electric fans, one fan is dedicated to the A/C and should come on almost the instant the A/C is turned on. The engine fan will run even with the key off, that is normal. The system is trying to cool itself. Hope this helps.
