Question about Acer Aspire 5330-2339 Notebook
My dvd rive is not reading a dvd cd is working properly. what should be done? very rarely it reads the acer driver dvd
  • 144 Answers
If its only having trouble with one disc , then the disc is probably dirty or the data on it is corrup
If it has trouble with many discs or all discs , then the drive is failing and will have to be replaced. As its a laptop , it would probably be cheaper buying an external USB dvd reader/burner than buying a replacement internal one as laptop parts are expensive and not readily available
If this has been of any use to you , please rate my solution below
Kind Regards
1234s282
Posted on Jul 03, 2009
My Acer Aspire cd /dvd drive isn't operating properly. I keep getting error message that I have no driver.
many cds/dvds get dirty by fingering on the reading side of them, use tops(ear-cleaners) to remove dirt from lens.
Apr 05, 2012 | Computers & Internet
It reads CDs, but DVDs: "Please insert a disk in drive.."
DVD SOHD-16P9S drive doesn't read any kind of CD or DVD
hi,there is no problem in drivers .
check the hardware parts
there are 2 possibilities in your case
1.the laser beam which reads the dvd or cds is malfunctioning
2.ensure that the cable & buses are properly connected
in case laser beam is damaged you got to get it repaired for proper functioning
all the best
Dec 19, 2007 | Lite On SOHD - 16P9S Internal DVD Drive
Dvd will not read
If purchased less than a year ago, it's under warranty. Get it replaced.
Warranties are normally for one year unless you bought an extended warranty. You should be OK.
Jul 07, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Acer 4520 cd/dvd driver problem
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
May 28, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Dvd's & Cd's are not being read
When this happen the problem is usually the CD drive, even if a virus can cause same problem.
To test if the problem is software, go to bios or boot options, set primary bot device CD/DVD, and start the computer with a boot disk inside.When asked chose boot from CD.
If the computer does not see the dvd drive, and does not ask you if to boot from CD on this conditions, then you have a faulty DVD RW drive.
Try first removing the DVD drive and refitting it in place, after removing battery and unplugging the AC adapter cord.
If that does not work, you usually need to replace the driver, even if on rare circumstances a faulty motherboard can cause the same.
That is however quite unusual.
the most common is a faulty optical drive.
May 16, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Acer Internal DVD RW Drive not working for "written" dvds.
The quality of the writable CD can make a big difference, and maybe run a CD driver cleaner as well.
Another thing to try is to write the CD at a lower speed, not the driver maximum, this can help with less quality CDs as well.
Jules
Apr 23, 2009 | Acer (91.AB264.023) Internal 32x CD-ROM...
DVD drive doesn't work
It's likely that you have a bad drive. Before rushing out to buy another one, remove the device for CD/DVD drive under Device Manager and restart the computer. Let Windows reinstall the driver and see if that helps.
Additionally, you might want to completely remove the drive, check the connections on the end, and also use compressed air to blow out inside where the connection is made.
If after all that, still not working ...bad drive :(
Sep 28, 2008 | Acer Aspire 3502WLCi Notebook
Laptop reading dvd only
The majority of the time when the drives stops reading either CD's or DVD's, it's a failed reader board in the drive. The drive has two reader boards in it, one for CD's, and one for DVD's, one can go out and the other will work fine because they are two separate boards or reading systems. It's common for the CD board to go out and leave the DVD intact, simply because the CD board has 10 times more use. Most likely you will have to replace the drive, however, there are a couple of other things that can cause it to do this, they are rare, but still occur occasionally. Start by uninstalling the drivers for the CD/DVD drive from the device manager, then reboot. The machine will find the drive automatically, and reinstall the drivers. If it's a glitch, this will cure it. You can also try a lens cleaning kit. You can get one at Walmart or Bestbuy for around $10. It's extremely rare that a dirty lens would cause this, but it won't hurt to rule it out. If these don't work, then unfortunately, your only option is to replace the drive.
Sep 05, 2008 | Dell Inspiron 6000 Notebook
DVD/CD
My CD /DVD is not recognised . I want to download driver . can some one help me pleaseeeeeeeeee.
scan-good.gif tree_v.gif tree_l.gif icon_cdrom.gif QSI CDRW/DVD SBW242C
Mar 31, 2008 | Acer TravelMate 2300 Notebook
Cd\dvd drive won't read software cd
Just a suggestion, try to update your drivers.. If you have installed any third party cd burner just uninstalled it. after uninstalling, clean the registry via ccleaner, regcure, or any other 3rd party cleaner... then update your drivers... most of the 3rd party cd burner software are damaging your cd drivers...
gud luck
Sep 27, 2007 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Acer Aspire 5330-2339 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
