Question about Sony Walkman TCD-D8 Personal Cassette Player
The plastic window came off from my walkman professional. What is the best adhesive I could use to get it fixed?
    Scholar:
  • 57 Answers
Takatani - I always use a 5-minute two-part epoxy for the strength of the bond. You mix equal parts and then you have 5 minutes before it sets well enough to hold. The two-part epoxy is available in longer cure times, but I like the 5-minute because I can hold anything in place for that long. If the plastic window will set nicely where it belongs for a long time, you can even use a simple contact cement. A super glue might even work, but I would use one of the other two. They are available at hardware stores and hobby shops.
Posted on Jul 03, 2009
BEST ADHESIVE FOR THE H D POLYPROPYLENE PLASTIC; SMALL HOLE IN REAR SPINE
Repairs are done using a hot poly material. No adhesives will stick to poly-plastic for very long. Check with manufacturer for the plastic material to be melted into the repaired area. Like hot glue
Feb 01, 2016 | Ascend FS10 Sit-In Angler Kayak - Camo
The plastic peg that attaches the deli drawer lid to the refrigerator wall broke off. I can see no way to fix it. The peg seems to be part of the fridge wall. It goes into a hole in the lid. Designers...
There are many specialist adhesives available today so broken plastic is no longer the problem it once was.
The main problem is such things as industrial strength superglue for plastics or ultraviolet curing plastics adhesive are fairly expensive and mostly not available from the average hardware store.
Trade outlets and suppliers to the plastic door and window trade or an internet search.
Nov 10, 2017 | Maytag Refrigerators
What kind of plastic is the "window" in a frigidaire front loading washer made of? Recently when my husband pulled on the semi circular plastic piece, which is part of the "window", it split, almost c
Hello Ann Calk -Unfortunately depending on which part it is exactly since there is any adhesive available to glue it back together you need to purchase the entire door panel. I would suggest contacting a professional to accurately diagnose and repair the window washer.
Sep 30, 2012 | Frigidaire FTF2140FS Front Load Washer /...
Chevy Astro rear window is loose, how do I fix it
Sounds like the glass tech either didn't clean the area good enough,didn't use a good adhesive,or just hurried to much.You can get the stuff you need at a good parts place(NAPA or Carquest are my favorites for professional products).3M adhesives are typically the best.Use a "piano wire" removal tool to take the glass out.Clean everything down to the bare paint with solvent."Glue in" window glass is usually installed with a urethane adhesive in a caulk gun tube.Read the side of the tube,make sure you have any primer it may call for before taking it home.(The manufacturer's instructions are the best to follow-they want you to like their product's results so you'll buy it again!).This IS a job the average gearhead can handle.Hey-the last "pro" you took it to didn't do it right anyway,so what'll it hurt for you to take a shot at it?
Jun 13, 2012 | 2002 Chevrolet Astro
My walkman nwz-b152f shows boot error
First, you go to DEVICE MANAGER. Under PORTABLE DEVICE, there is your WALKMAN. Right click on the WALKMAN. Choose UPDATE DRIVER SOFTWARE. Then, LOCATE AND INSTALL DRIVER SOFTWARE MANUALLY. Then, choose LET ME PICK OF DEVICE DRIVERS ON MY COMPUTER. Currently you are using MTP USB DEVICE...so, now choose USB MASS STORAGE DEVICE. Then, click next. Once u have done all this, format your walkman. Your walkman should be fixed. :)
I had the same problem with you before, and i tried this. My walkman has working like usual, now. I'm using Windows 7. So, best of luck!
P/S : U also can change back your driver to MTP once your walkman had fixed by doing the same step. ^^
Feb 11, 2012 | Sony Audio Players & Recorders
The handle fell off the kettle, how can I re-fix it?
If it do not have any obvious way to fix it (locking clips or screws) and it was just inserted on the metal part ..than you can use some kind of glue for plastic and fix it back again .a super -glue will work or a strong plastic adhesive .Clean both ends so that any grease to be removed...and apply the adhesive on the plastic end .. and than insert it to the metal end ..in such a way that the adhesive to fill the space and the excess substance will drain off when you press them together. leave them to react for a while without touching them ..be sure you choose a temperature resistant adhesive ...
Nov 16, 2011 | Alessi Al384730-640 Cordless Electric...
The brackets that attach to the driver's window on my son's 2003 Grand Am have broken due to forcing a frozen window. The window is no longer attached to the slide mechanisms. I am wondering...
Hello, normally just the window sashes break. this is the plastic part that is glued on the bottom of the glass. you can but these asahes at your dealer. they simply just glue on with a special glue
Sash Channel Came Off Glass; Adhesive on Glass
  1. Remove the door glass and lay it on a protected table.
  2. Mark the location of the clip with tape.
  3. Remove the adhesive with a one edge razor blade.
  4. Clean the glass with Isopropyl alcohol.
  5. Important: Install adhesive into the applicator and squeeze some adhesive out before you install the mixing tube. After the mixing tube is installed, run a test bead the length of the mixing tube to ensure a good mix.
  6. Fill the sash channel clip with adhesive.
  7. Install the clip in the marked location.
  8. Reinstall the door glass and put the glass in the full up position for 24 hours.
Cut off the bottom edge of the guide with a cut off wheel. (Refer to the illustration above.)
Using a thin flat blade putty knife and a hammer, carefully remove the plastic piece on each side of the glass. (Refer to the illustration above).
  • Clean any adhesive from the glass using a one-edge razor blade. (Refer to the illustration above).
  • Clean the glass with Isopropyl alcohol.
  • Important: Install adhesive into the applicator and squeeze some adhesive out before you install the mixing tube. After the mixing tube is installed, run a test bead the length of the mixing tube to ensure a good mix.
  • Fill the sash channel clip with adhesive.
  • Install the clip in the marked location.
  • Reinstall the door glass and put the glass in the full up position for 24 hours.
  • 22689012
    Sash, Side Door Window
    12378568 (US)
    88901676 (Canada)
    Structural Urethane Installation Adhesive
    Jun 06, 2011 | 2003 Pontiac Grand Am
    Install luan over concretehow to secure plywood screws or glue?
    You are much better off using an adhesive rather than screws. Home depot sells several good flooring adhesives, usually in aisle 8 that will do the trick just fine
    Sep 10, 2009 | Wise Solutions Wise Installation System 9...
    The small piece of plastic (with BOSE on it)that
    You can have Bose replace the headset for you (new w/ 1-year warranty), but if it's past it's current 1-year it will cost you $60.Unfortunately Bose doesn't supply parts for that headset, but you could try using plastic adhesive as a low-tech fix. First Google search result for plastic adhesive:http://solutions.3m.com/wps/portal/3M/en_US/Windows/Doors/Product-Information/Products/Adhesives/Plastic-Adhesive/ .
    Jun 11, 2009 | Bose TriPort Consumer Headphones
    Sony Walkman TCD-D8 Personal Cassette Player Logo
    102 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
