Question about Home
Master toilet burps when flushed plus the shower drain smells bad
Sounds the same as this guys problem plus, my shower drain stinks when we start the shower. And there is a constant black haze in the toilet. Almost like sand. How and where do i get up on the roof to check this vent cable?
  • 156 Answers
It is a vent pipe. It will be the one on the roof, closest to the problem. Sometimes, squirrels will drop nuts in it and stop it up. If that is the case, you may need a plumber. It could be partially blocked. You should have a trap on the shower but if there is not enough air for it to vent, it could cause what you're saying. If you don't want a plumber, you can figure out where the vent connects to the pipe, cut in the wall or cabinet, and check it there by cutting into it. Most plumbers have a cleanout that will clean this pipe out though. Hope this helps.
Posted on Jul 03, 2009
Found an over flow in our bathroom. When we checked the shower. There,me were small particles on the floor of the shower. Now there is sewage smell coming from the shower drain.
The smell might be sewage or just stagnated build up of a mix of things . try to use a plunger to make sure your shower drain is not blocked in any way , to use a plunger correctly you will need to block the drain hole and fill the shower with hot water and remove what you have covered the drain with and start plunging while the water is running down the drain , this gives maximum effect while using your plunger , some material may want to expel out the top of the drain while other material will be forced down and along the waste pipe after you have done this pour a large cup or two full of liquid bleach down the shower drain and see if this clears the problem ,because most sewer systems are independent from the waste water of sinks, showers and washing machines. Also when you flush the toilet try adding a bucket of water at the same time as you press the flusher , this will force more water than usual down your toilet helping to keep the pipes fully open , but if you notice that when you flush and add the bucket into the bowl at the same time that the water does not escape freely and seems to back up , this can be a sign that there may be blockages in the sewer pipes and you might try doing this extra water flush a few ,more time hoping you will clear your pipes adding some Landry washing powder to the bucket can have a effect on moving anything along and hot water is beneficial as well . But I think you will find that the shower drain is what is causing the odour pouring a mix of vinegar and baking soda down the drain as a regular maintenance job keeps them odour free and unblocked .
Sep 24, 2017 | Home
Toilet burps when tub drains
More than likely the shower drain is not vented to air.
Jun 04, 2014 | Plumbing
My toto neorest 500 "burps" when I flush but the water does not go down
The problem may be in the venting of the toilet. If the vent for the toilet is plugged or in the northern climates frosted shut the air in the toilet drain has nowhere to go when displaced by the flushing water so it backs up through the toilet and causes the "burping" you mentioned. Hope this helps.
Dec 12, 2013 | Toto Home
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
When I flush my macerating toilet the shower floods with the toilet waste. How can this be fixed.
you have a blockage in drain system. also make sure the air vent is ok.
Jan 18, 2012 | Saniflo Home
I have a saniflo and the shower doesnt drain straight away and when u flush the toilet it bubbles up the shower !
This sounds like a HOUSE plumbing issue. Is the line porperly vented? Bubbling sounds like the line needs venting. If you cannot go through the roof, they now make local vents that work.
Jul 11, 2011 | Home
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Home Logo
281 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
