Question about Cosco High Back Booster 22-200 /22-207
What are the height requirements / limits for this car seat?
I have a model 22253 that looks simular.
For children 22-80 pounds and 34"- 52" in height
Posted on Aug 20, 2009
What are the safety precautions I should consider when buying a balance bike?
  1. Seat height.
  2. Size.
  3. Tires.
  4. Weight.
  5. Brakes.
  6. Turning limiters.
  7. Footrests.
  8. Frame materials.
  9. Grips.
Jul 18, 2016 | Strider ST-3 No Pedal Balance Bike Cobra
DO GRACO SNUGRIDE INFANT CAR SEAT BASES WORK WITH A DIFFERENT MODEL?
Some do, some don't.
From Graco's web site:
What base will work with my car seat?
We have designed many of our car seats to work with more than one base, for your convenience. Please see the chart here for Classic Connect models.
The SnugRide Click Connect 30, 35, 35LX and 40 infant car seat carriers are compatible with any SnugRide Click Connect infant car seat base. Consumers should adhere to the height and weight requirements for the SnugRide Click Connect infant car seat carriers as stated in their owner's manual; however, the SnugRide Click Connect 40 infant car seat carrier is restricted to a height limit of 32 inches when used with a SnugRide Click Connect 30, 35 or 35LX base.
Jun 15, 2014 | Graco Baby Gear
Seat height on a r1200cl needs lowering
Hi, Anonymous here are some options for lowering your bike depending on your needs and wallet:
1. Rear shock lowering kit.
2. Front fork lowering kit.
3. Shorter rear shocks.
4. Shorter front forks.
5. Thinner padded seat.
6. Lower profile tires.
Please be aware that some of these options or a combination of options will require a shorter kickstand or your stock one modified. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Can the seat height of the 2004 bmw 1200 cl be lowered
What are lowest motorcycle seat heights Motorbike Writer
http://www.carlsalter.com/download.asp?p=297
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Sep 11, 2013 | 2006 BMW F 650 GS Dakar
Huffy mx 80 can you higher the seat.
Raising the seat is limited to how much seatpost you have available.
To determine the amount of seat height you have available you need to pull the whole assembly out of the frame. At the junction of the frame and seatpost there is a bolt, loosen that bolt and lift straight up and the assembly will come out. On the end of the seatpost where it inserts into the frame look for a limit line. Insert the assembly back into that line and that is the maximum height the seat can go.
If you need it higher you will need to purchase a new seatpost from yoiur local bike shop. Make sure you take them either the bike or seatpost as they come in many different sizes and they must match diameters exactly.
Dec 04, 2010 | Huffy Cycling
My speed indicator lights are constintly flashing- the chair works fine though
You don't say what sort of chair you have, but if it has tilt or power seating system, the speed lights flashing could be a power-limiting warning, which means you have the seat tilted or raised too high for full power so it is limited to going slow. Lower seat and then try to drive it an normal speed. If the seat isn't tilted or raised and lights are flashing, then the switch on the chair that senses the height or the tile is probably faulty and would require replacement. Do NOT disable or bypass the switch as it is a safety device to prevent unsafe operation.
May 23, 2010 | Jet 3 Ultra Power Chair
As I do not have a manual, what is the height & weight limit for this model? Secondly, does this particular model have the ability to be used as a booster seat?
By law, the height and weight limits should be on a label on the side of the car seat. If it has worn off or been removed, the manual or the manufacturer's website is your only reliable answer. Most manufacturers allow you to download a manual from their website if you have the model, model number and date of manufacture.
Apr 16, 2010 | Evenflo Triumph 5 - Aztec Ceramic...
Britax Boulevard-Is there a weight limit for latch system?
The weight limit for the UAS / Latch system is 48 Lbs. Read your owners manual for both the Car seat and your vehicle to be sure of all the regulations.
Jul 03, 2009 | Britax Boulevard
Height requirement
should not be jammed and neck with head supported.
Jun 05, 2009 | Evenflo Triumph 5 Comfort Touch
Discovery 5 3 little bears car seat
You should never put your baby in a car seat in their snowsuit. It counts as extra padding, and voids all the crash testing done with your car seat. It is NOT safe! You should instead put your child in the seat with just normal clothing, tighten until it's very snug. You should not be able to pinch your strap at all, then put a blanket on top of the straps. There should be a tension adjustment. Read your user's manual. If you don't have one, call the manufacturer and they can email you a virtual copy. If the tension is let all the way out, your child has probably outgrown the seat. Check the manual for height and weight limits. My boys grew out of their infant seats at 4 and 5 months old! It was an older Discovery model, but I suspect the height limit is still a measly 26 inches, instead of 29 inches like most seats. They weren't even CLOSE to the weight limit, but had to move to a convertible seat anyway. I need a new seat for the baby who will arrive in a few months, and I will be paying more $$$ for one that has a higher height limit.
Oct 28, 2008 | Evenflo Discovery 5 Infant Car Seat - 3...
Weight and Length Limitations??
Thanks very much for the info!! Problem solved! I ende up going to Sears and I read the manual that came with my car seat. The weight is from 5-22 lbs and the height is 27"-29" long. Thanks again for all your help.
Aug 20, 2007 | Eddie Bauer Lightweight Travel System...
Cosco High Back Booster 22-200 /22-207 Logo
335 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
