We just changed the filter and ran the water, however, it's still leaking
Was it leaking before changing the filter? It could be that the water valve in back is leaking a bit. Sometimes the valve gets a very small bit of grit in it and doesn't completely shut off. The way to tell is to remove the hose from the valve and see if water is dripping from it at the valve. If it isn't then maybe the water reservoir is partially frozen and causing a pressure build up in the reservoir. If this is the case the dripping should stop after a couple minutes. I would look at the valve.
