BEHRINGER MX 9000 POWER SUPPLY NEEDED
Our church recently experienced a power surge that went through oursurge protectors and also burned out our behringer mx 9000 powersupply. How do I locate one to replace the one that was burned out. There is nothing wrong with our console, and now we can't use it.
  • 156 Answers
No power to computer, flashing green light by power cord
reset the surge protector first!
then investigate the power supply
Mar 27, 2012 | Compaq Computers & Internet
During a recent storm our power went out and a family member was on our Gateway 504GR. Since the power came back on, the computer will not turn on. It was plugged into a surge protector and all other items...
Suggest the Power Supply took a 'hit' from the storm. Hopefully this is all that received the power surge.
Surge protectors are a necessary item, but in reality it takes an Expensive surge protector, for defense against a lightning storm, and even that isn't a sure bet.
(Lightning strikes can produce over a Million volts)
Also, I have had three surge protectors where just THAT receptacle was bad.
"Hmmmm, surge protector power on LED is lit. Printer has power, monitor has power, and router has power. Surge protector must be good."
NOT.
Just THE receptacle the computer was plugged into was bad.
Past this test, I would suggest diagnosing the Power Supply.
A) Test the Power Supply voltages
B) Use a KNOWN to be Good, Compatible power supply, for a test unit.
C) Buy a power supply, and replace it.
Granted, not a professional approach, and could result in a waste of money.
Some do approach repair in this manner, however.
Going backwards.
C) The Gateway 504GR desktop computer uses an ATX style of power supply, and is rated at a maximum Wattage rating of 300 Watts.
(ATX case is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall)
Gateway Support > 504GR desktop computer > Support Documents main page,
http://support.gateway.com/s/PC/R/3724/4365nv.shtml
If you Left-click on - Components, you will see a list of components used in the 504GR.
Scroll down to the heading - Power Supplies
Left-click on the blue -
102015 - 300 Watt Power Supply, heading.
It's just a generic ATX power supply with a,
1) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ Power for the Intel Pentium 4 processor. Plugs into the motherboard ]
3) (1) SATA power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[Power for the SATA harddrive ]
4) At least two 4-pin Peripheral power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
[Power for the CD drive, and the DVD drive ]
This is just one example of a decent, reliable, economical Power Supply, that will fit the bill,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
B) The above explains the minimum Wattage needed for the test unit, the size, and shape of the case, and the needed power cables, in case there is a power supply around to use for a test unit.
(Some have an older unused computer sitting in a closet, or what have you. The computer can be temporarily cannibalized for the power supply)
1) That SMPS (Switched-Mode Power Supply) puts out three DC voltages.
A) 3.3 Volts
B) 5 Volts
C) 12 Volts
(Two C cell flashlight batteries produce 3 Volts DC)
The test is done for the 12 Volt power rail.
ALL Yellow wires in the various power cables, are 12 Volt wires.
They all go back to one 12 Volt power rail inside the Power Supply.
[Orange insulated wires are 3.3 Volts.
Red wires are 5 Volts ]
11 to 13 Volts indicates a good Power Supply.
Less than 11 Volts means it's time to replace.
You can use a multimeter to check the 12 Volt power rail, or a power supply tester.
One example of a power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
An economical multimeter good enough for this test, can be purchased from $5 to $12.
The Power Supply is unplugged from power.
The Positive (Red) probe lead of the multimeter, is connected to ANY Yellow wire.
The Negative (Black) probe lead is connected to ANY Black wire.
(ALL Black wires are Ground wires. They all go back to one central Ground source inside the PSU.
{Power Supply Unit. Another term for Power Supply. Also another term for the SMPS, used in personal computers)
To reply just Left-click on Comment. (Believe upper right of your page )
Jun 20, 2010 | Computers & Internet
My desktop dont come on
1) Check THE receptacle in the surge protector the computer is plugged into.
I have found more than once that One bad receptacle in the surge protector is bad.
"Hmmm, surge protector power on light is lit." "Monitor has power, amp for the speakers has power, and the router has power."
All plugged in to the same surge protector.
Tried a table lamp into the receptacle the computer was plugged into, Nothing.
Replace surge protector.
2) Bypass the Soft Power On of the Power Supply, and see if the problem is the Power On switch, or the Power Supply.
If you bypass the Soft Power On of the Power Supply, and the Power Supply comes on, the problem is a bad Power On switch.
If you bypass the Soft Power On of the Power Supply, and the Power Supply does Not come on, the problem is the Power Supply.
If you wish to know how to perform this simple test, just state so in a Comment.
(Believe upper right of your page)
Jun 17, 2010 | E-Machines eMachines Desktop PC
Computer/Motherboard Issues
buy a circuit protector for just ur computer and call a electrition
May 12, 2010 | Gateway 507GR PC Desktop
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
Power supply shot when 3 weeks on same surge prot. all other eq. ok
YES !! IT CAN DAMAGED THE POWER SUPPLY , WHAT i SUGGEST IS TO USE AN APC BATTERY BACK UP & SURGE PROTECTION , SAME USE FOR COMPUTERS , FOR MORE INFORMATION GO TO:
http://www.apc.com , hope this helps , AJ
May 18, 2009 | Maxent MX-27X1 27 in. HD-Ready LCD...
Looking to purchase a Behringer MX-9000 power supply
The desk itself is discontinued, however if you have a ring round the Behringer dealers for your area, they might have stock, or be able to obtain a spare power supply for the desk. Failing that, you're in the second hand area, so a popular online auction site, or google for people selling one. Unless they have a broken desk though, you might find that they only come together with the desk.
Sorry can;t help more!
Mar 05, 2009 | Audio Players & Recorders
Power issue
Sounds like your power supply may be shot on your computer. You can get a power supply tester and check it. Not sure what to do about the printer. If you had a surge protector in between your computer and ac. Plug the computer and printer back in to the AC outlet directly and see if that helps. Hopefully only your surge protector is damaged.
Please rate, Thanks.
Feb 09, 2009 | HP PSC 950 All-In-One InkJet Printer
Behringer eurodesk mx9000 Power supply problems
After a little research I discovered that Behringer has had problems in the past with there power supplys so I replaced the faulty one and so far the problem has been solved. Our local power company has been sending to much power to our church building and that is what caused to old power supply to burn out. We are still trying to get them to take care of their issues.
Sep 19, 2008 | Audio Players & Recorders
200 people viewed this question
 Grubhead
Grubhead
