P4Vmm2 motherboard I had changed my cpu housing... i was disoriented with the wiring connections from the power to audio, usb, etc. Can you help me... a schematic drawing.. picture.. that has connections will be great. Thanks
  • 3 Answers
Have you tried going to manufacturers site and downloading instruction manual?or googling the make and model asking for intruction manual or diagram,you have the WORLD WIDE WEB someone somewhere will have that information
Posted on Jul 03, 2009
Emachine W3653 motherboard manual
Intel 945GCT-M3 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rmv.shtml
Above shows main view, and is labeled.
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtml
Click on Product Views for Pinouts and connectors for;
1) 4-pin ATX +12 Volt power cable; B - Processor Core Power Connector
2) Processor fan cable connector on motherboard; D - CPU Fan Connector
3) 24-pin ATX main power cable; F - ATX Power Connector
4) Floppy Drive 34-pin connector on motherboard; G - Floppy Disk Drive Connector
5) CD/DVD drive that is IDE (PATA) type -> connector;
H - Parallel ATA IDE Connector. (Harddrive goes to SATA connector)
6) Computer case fan connector; I - System Fan Connector
7) Audio connector on motherboard for CD/DVD drive's small audio cable, (Main drive if there are two)
M - AUX-IN Connector
8) Front Panel is front of computer.
N - Front Panel Audio Connector is where the front panel audio ports connect.
9) R - USB 2.0 Connectors = Front Panel USB connectors on motherboard
10) Front of computer is the Front Panel. Area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
T - Front Panel Connector = Front Panel header
Motherboard manual from ECS Support,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0
(Note photo is distorted. Click on - More pictures for clearer view.
{More pictures / Where to buy / Print )
Click on the Download tab.
(Features / Specification / Download / Support / CPU / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down, click on the country NAME nearest yours.
A PDF file motherboard manual will come up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 16, 2012 | Computers & Internet
HOW TO CONNECT USB 2.0 TO FRONT PANEL BY HOST VIA
follow this link for information on how to connect your external USB ports.
Select the version of your board and download the manual. this will give you exact instructions.
Hope this helps.
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=P4Vmm2
Mar 22, 2011 | EliteGroup P4VMM2 Motherboard
Specifications only
CPU º Socket 478 for latest Intel Pentium 4 / Celeron processor
º FSB 533/400 MHz
º Support Hyper-Threading Technology CPU
CHIPSET º VIA® P4M266A & VT8235
º North Bridge: VIA® P4M266A
º South Bridge: VIA® VT8235
GRAPHICS º Integrated S3 ProSavage8 2D/3D Graphics
º Share Memory : 8/16/32MB
MEMORY º 2 x 184-pin DDR DIMM socket support up to 2 GB
º Support DDR266/200 DDR SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT º 1 x AGP 4X slot
º 3 x PCI slots
º 1 x CNR slot
STORAGE º Support by VIA® VT8235
• 4 x Ultra DMA133/100/66 devices
AUDIO º Realtek ALC655 6-Channel audio CODEC
º Compliant with AC'97 2.3 specification
LAN º VIA® VT6103 10/100 Mbps Fast Ethernet PHY
REAR PANEL I/O º 1 x PS/2 keyboard & PS/2 mouse connectors
º 4 x USB ports
º 1 x RJ45 LAN connector
º 1 x VGA port
º 1 x Parallel port (LPT)
º 1 x Serial port (COM1)
º 1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS º 1 x 20-pin ATX Power Supply Connector & 4-pin 12V Connector
º 1 x FDD connector supports one 360K~2.88MB FDD
º 2 x IDE connectors
º 1 x IrDA for SIR header
º 1 x SPDIF out header
º 1 x USB 2.0 header support additional 2 USB ports
º 1 x Front panel switch/LED header
º 1 x Front panel audio header
º CD in/ AUX in headers
º CPUFAN/CASFAN connectors
SYSTEM BIOS º Award BIOS with 2Mb Flash ROM
º Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
º Supports ACPI revision 1.0 specification
FORM FACTOR & LAYERS º Micro-ATX Size (244mm*244mm), 4 Layers
for more detail look at this site
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=436&CategoryID=1&MenuID=18&LanID=19
i hope this helpful
thank you for using fixya
Feb 06, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
Why wont the mouse,keyboard and monitor not work after cpu,pwer supply install...
If the motherboard used to work with the old cpu and power supply, but does not with the new cpu and power supply, then probably the cpu or power supply is bad.
Why did you change the cpu and power supply?
If the power supply went bad, it could have overloaded the mother board as well as the old cpu.
If you think the old cpu went bad, how do you know it was not actually the motherboard that went bad?
All I can suggest is that you double check all the connections.
If you have USB mouse and keyboard, try a DIN connected pair.
If you are using the onboard graphics, try a PCI express card instead.
Tell us if there is any front light activity from the power switch, drive, etc.?
Dec 21, 2010 | Biostar P4M900-M4 Motherboard
I hav a problem no audio device in my mercury CPU,wht audio device is nescessary how can i find it
First go to the manufacturers site and download the audio drivers
If that doesn't work, i recommend you to but a PCI sound card
Guess that'll help
Dec 30, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
CPU upgrade not showing correctly
Check the installation instructions; it may be necessary to change some small jumpers on the board if it is not designed to auto-detect the processor.
If you don't have the info on the board, check with Safemanuals.com or retrevo.com or Elite's website for a download.
Sep 21, 2008 | EliteGroup ECS P4VMM2 Supports Intel...
P4VMM2 motherboard
You can download the manual from here (Europe) or here (US).
Sep 17, 2008 | EliteGroup P4VMM2 Motherboard
P4vmm2 motherboard wont start
cheak and change ur power supply
Jan 05, 2008 | EliteGroup P4VMM2 Motherboard
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
220 people viewed this question
Alun Cox
David Payne
David Payne
