Question about Kodak EASYSHARE V1253 Digital Camera
My camera shows light for a bit but does not turn on. I have charged the battery for more than 2 hours.
  • 156 Answers
How old is the battery? If you have a volt meter, check the voltage on the battery after you charge it. The voltage should be marked on the battery. Hope this helps.
Posted on Jul 03, 2009
HD camera.flip style
Did you do the Setup when you first started it? by holding the red button and following prompts? (to set up Language, date etc.) - if not try that. if yes, have you tried recharging it? Mine takes about 7 or 8 hours to fully charge (the red light will come on then when fully charged that light goes out) - it appears you have Ultra HD like me, so you should also be able to try some regular AA batteries in place of your rechargeable just to try that. If it works then, it is your rechargeable battery pack - either no good or needs charge. also when plugged into USB that red light should come on on front of the camera and if you look at the screen it should show a battery icon with a lightning bolt over it, shows the battery -how much charged. after 6 or so hours, press your red button and look at the screen - it now should be showing a battery icon that should by now be mostly Green and almost fully charged.
While charging the unit, Flipshare software comes up on your computer, "X" out of that software, so your camera will charge faster. My camera was doing similar things but I've had it a long time, and regular batteries worked, So I ordered a new battery pack and it has been fine since. Good Luck!!!
here is link to "what to do if battery not charging"
Jun 04, 2013 | Cameras
Troubles Turning Camera On
What kind of camera is this? I suggest calling the company such who will take time on the phone and work with you to fix the issue. Didn't have the same problem but have a Nikon and they assisted me over the phone almost an hour working with me to solve the issue.
Mar 25, 2017 | Cameras
I need to recharge my battery on my vivcam t328
This one is a bit different as the battery can be swapped out but the only way to charge these is to plug in the usb cable into the camera and into a usb port on your computer. The computer has to be running.and the camera has to be turned off. You will see a green light that shows it charging when the battery is charged the light will go out. Depending on how much power the port supplies it can take 3-8 hours. As long as the port is supply power it really doesn't matter what computer it is on as you are not transferring picstures so don't worry about plugging it into any thing that running to get a charge.
Dec 28, 2011 | Cameras
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
The battery is run down every time I come to use the camera. So it seems to bleed out power even when turned off. I have replaced the original battery and the new battery also runs out while sitting turned...
This is not a common/generic problem for this camera, we need to be a bit more creative into it resolution.
I am assuming that you have already checked for accidental 'power on' of the camera prior to reporting it. By accidental power on, i mean that as this is one of those semi-pro dslr cameras you need to make sure that the power is turned off before you replace the lens cap as otherwise you can mistakingly leave the camera on while the covered lens will show nothing on the lcd/viewfinder display.
Check the time it takes for you to charge your battery. It should take a minimum of 5.5 hours to charge the battery fully. If the charging light on the charger turns off before then, continue charging for the next couple of hours. Try using the batteries again. Also, please note that temperature is very important both during usage and charging. As per Sony, the optimum charging temperature is 25 degrees C or 77 degrees F. In colder areas, battery power runs out extremely fast.
Aug 21, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
Not charging?
Please plug the camera charger in AC Outlet and hook it to camera. Check camera power turn ON, works fine? if OK, switch it to Standby / Off mode. Attach battery and check any charging light lit? If yes, leave the camera on charging position for 4-5 hours until its charge light flashs or turn Off. battery is chaged now. Have fun :)
Aug 13, 2008 | Sony Handycam CCD-TRV37 Camcorder
Battery Problem
Sorry this isn't a solution, but I wish my 8700 would last even as long as yours does. 2 hours, period. on or off, taking pictures or not, two hours & it's a stone dead battery. Just on the off chance it will help I'm about to upgrade the firmware to 1.3 (I don't really think it will help). After that I've decided to take the camera apart & try to find the problem or possibly just a hack that will let me turn it OFF without removing the battery. I'd as soon have a bunch of bits for the project bin as have to put up with this 2 hour battery life problem. Good luck with your problem, and if I find anything worth while I'll post back.
Sep 28, 2007 | Nikon Coolpix 8700 Digital Camera
DSC-T7 Power Problems
The only and the only solution is to get the replacement as this seems to be a defect in the camera and you should get it change immediately.
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Kodak EASYSHARE V1253 Digital Camera Logo
182 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
