I've now replaced my dryer valve coils for the third time in 4 months. So something is causing them to break down. The problem is the same each time... the coil with three prongs loses continuity. Any thoughts?
I hate to say it, I only had this happen 1 time in 25 years I been doing repairs. It would have to be the Valve the coils are mounted too. I'm not 100% on this but the 1 time I had it happen to me it went bad 3 times in a month, I spoke to maytag tech hotline and they suggested it, and it took care of the problem for me.
SOURCE: Kenmore Serios 80 Gas Dryer - Replacing Gas Valve Coils
I haven't done coils in a while, You will need to remove the top and front panel to access the coils. The top should have catches that allow you to grasp the top by the back corners and pull forward slightly releasing the catch for left an right sides, other will have to have the top console removed to reveal 3 hex screw to pull the top off. Once done get a 5/16 and remove two hex screws left and right on the inside edges holding the front on, also unplug the harness to the door switch, by now the machine should be unplugged. the coils have a flange over them held on by some phillip screws. the orifice is preset so dont mess with adjustments, they should pop out and pop in
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
SOURCE: Dryer gets warm at first but then cools down
Check the hi limit thermostat and the cycle thermostat. They may be opening too soon.
Remove the connecting vent on the rear of the dryer exhaust and see if it cycles normally.
The flame sensor may be malfunctioning.
If the gas valve coils are good, these are the only other possibilities.
SOURCE: How to replace gas coil valves on Whirlpool LGR5636EQ3 Gas Dryer
DOES YOUR DRYER HAVE THE LINT SCREEN ON THE TOP? IF SO, REMOVE THAT AND TAKE TWO SCREWS OF(CARE NOT TO DROP IT INTO THE VENT). PULL THE TOP PANEL TOWARD YOU LITTLE BIT AND LIFT UP, THERE WILL BE TWO 5/16 SCREWS INSIDE FRONT PANEL, REMOVE AND UNPLUG THE LID SWITCH CONNECTOR, FRONT PANEL WILL COME OUT. THE GAS VALVES AND COILS ASSEMBLY WILL BE ON THE BOTTOM RIGHT. UNPLUG AND TAKE THE SCREWS OFF THE BRACKET AND REPLACE COILS. CHECK FOR CONTINUITY ON COILS, IT SHOULD READ 1.3 TO 1.9 OHMS. THE ONE WITH THREE TERMINAL, CHECK OHM FROM MIDDLE TERMINAL TO OUTSIDE TERMINALS.
[email protected] 714-334-1998.
You have a bad flame sensor. Replace it.
