HOW TO RECHARGE SPLIT TYPE AIR CONDITIONER WITH USING r22
RECHAGE
MAINTAINED
Check cooling coil(in door unit)if there ice buil up then feel air vent if no air mean your fin block aready need to clean / air vent ok meant there have a leak .you need r22 test gauge and hose,reamer,tube cutter and flaring kit. 1)check suction pressure(big tube at out door unit) remove 2 way cap and 3 way cap valve then connect blue hose at service port 3 way valve (port locate at left or right depent on manufacturer) you will get pressure about 40-45 psi(air cond is running) then use a allen key(hexagonal wrench) to close 2 way valve(small tube or gas discharge side) wait 1-2 minute then close 3 way valve (suction tube or big tube) IMMEDIATELY SHUT OFF AIRCOND AND PLUG OUT POWER CORD (you need 2 person one at in door unit and the other at out door unit). this method is to keep remaining gas inside the compresser.Then leak check ,open 2 way valve about 90 degree hold it for 10 minute then close it .MEASURE THE PRESSURE keeep it for 5-10 minute. If the pressure indicate not same during the first time measured it meant there have a leakage, for air cond 1- 5 year the leakage will happen at the copper tubing connection and improper flaring .Then U need to clean in door and out door unit ,used a spanner or wrench to losen the copper FLARE NUT at out door unit and in door unit( inside insulation) then use pvc tape to cover all copper pipe/tube hole to prevent dirt go inside tube/pipe. Then lift up out door unit and used coil cleanner ditergent wait 5 minute then flush with water. Remove indoor front panel then disconnect out door unit cable at front panel in door unit then lift up indoor unit to disangage the hook and pull out the indoor unit, then clean the cooling coil ,cover electrical part with plastic .last step u need to cut (used cooper cutter)the copper pipe/tube FLARE NUT connection low side(big tube) and high side(small tube) in door connection and out door connection .Then u need to remove the burr from cut edge using reamer make sure metal powder not goes in Then make a flare after inserting FLARE NUT onto the copper pipes Then U can install back the unit check the low side pressure if the pressure 55-67 psi no need to charge
Posted on Mar 23, 2010
  • 1 more comment
  • shahraimi Mar 23, 2010
    then check gas leakage using same method that already explain.suction pressure 55-67 psi in running mode and set to lowest temp(16 degree celcius) If not u need r22 gas tank, connect yellow hose to r22 tank and middle connection at test gauge .Then fully open tank valve and crack open blue stem at test gauge (DO NOT exceed 100 psi to prevent flooding the compresser) for 30 second to 1 minute then close it, measure the pressure for 1-3 minute.Repeat this step until u get 67psi in running aircond or u can feel suction pipe/tube cool.If your unit alreday empty u need r22 lubrication and weigth scale put r22 gas tank on scale and read at out door unit tag how weight recomended by manufacturer ,Then u need to fill yellow hose with r22 lubrication about 5-10 mililiter .Then repeat charge method that alredy explain and measure the weight of the gas and done
    What is "Super heat"?
    You will hear and see this term all the time in reference to refrigeration. Simply put it is the difference between the temperature of a vapor line in relation to the temperature scale on a pressure gauge for a particular refrigerant or how much liquid is feeding the evaporator in relation to how fast it is being boiled off. for example (R22) if the suction gauge reads 70 psig then the evaporating temperature is 41 degrees but if the tubing is 51 degrees then you have 10 degrees of Superheat. A typical range for residential air conditioning is 8-18 degrees with some error based on extreme conditions. Once you understand Superheat you can diagnose obvious problems. For example a system that is under charged or has a stuck (closed) metering device will have high super heat (over 20 degrees) at the compressor and a system that is grossly overcharged or has a dirty indoor coil will have very low Superheat about 3-7 degrees with low suction pressure and the suction line will be very cold. It is ok and quite normal for the Superheat to change dynamically while the system is running, you will have to interpret what you are seeing.
    What is "Sub cooling"?
    Sub-cooling is similar to Superheat but happens in the condensing portion. Refrigerant when condensing will happen at a particular temperature which is very close to the temperature scale corresponding to head pressure for a given refrigerant. After the refrigerant is condensed it will try to assume ambient temperature but will never reach it. The difference between liquid line temperature and condensing saturation temperature is Sub-cooling and is a very good indication of "refrigerant level", but only when proper Superheat is indicated or you could have a misleading indication. Typically 20 degrees of Sub-cooling is desirable and the closer the liquid line temperature is to ambient the better (indicating an efficient system). Checking Subcooling in the heat mode of a heat pump has to be done carefully because you have influence of the space between the indoor coil and the point of measurement. For best heating you will want most of the refrigerant to be condensing in indoor coil without backing it up with refrigerant.
    As a general rule Subcooling = Refrigerant charge quantity, Superheat = Refrigerant cycle performance. Check both!!!
    u need to purge air inside piping/tubing by using leakage check method but just used service port no need to used test gauge crack open 2 way valve for 10 second then close it then push the pin(same like tyre pin) at service port 3 way valve for 3 second repeat this three times also u need to purge all air inside test gauge and hose
    Sergeant:
  • 340 Answers
Hook up your gauges to the unit charge to proper super heat and sub cooling Or to that data plate specs. oh ya purge all of your hoses of air I call somebody with a license and have it properly serviced. Tom
Posted on Jul 03, 2009
Is it better to by air conditioners with R - 410 GAS OR R - 22 GAS
R410 units are cheaper now but not as effecient as R22, also R22 is much more expensive and most likely you would have to use R22 a to recharge unit if it as allowed where you live .
Oct 02, 2014 | Cfm Daikin R410a Split System Air...
Wire diagram picture for split system air conditioner
THEY ARE NOT ALL THE SAME NEED MORE INFO ON TYPE
Aug 15, 2014 | Heating & Cooling
My Fedders AC in my 2003 Roadtrek runs but doesn't blow cold air. Can't find valve in order to recharge it. Can you tell me where it is?
Window Air Conditioner are sealed at the factory,
no service valves & you can not buy R22 without
a licence
If you had to add refrigerant,common sense would
say you have a leak
Seldom repair that type of unit
It can be repaired sometimes, but usually they are
20 years old & you get a new one
Jul 16, 2011 | Fedders Q Chassis AEQ08F2E Air Conditioner
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
We have an Airwell Split Wall Mounted Air Conditioner bought in 2001. It needs regassing but we have been told this is not possible. Any reason why?
Hi
The old Airwell units were filled with R22, the use of R22 is now forbidden, however there are drop in refrigerants that can be used, even with mineral oil compressors, the most common is R417A
You need to contact your local experienced and helpful tech to recharge this.
Regards
Gordon
Jun 16, 2011 | Heating & Cooling
Where do you recharge the AC with r22?
Most rooftop RV units do not have service ports installed. You would have to get line tap valves to install in the system. The next problem would be getting some R22. Unless you have and EPA CFC certification you cannot buy R22.
Sep 25, 2010 | Coleman Mach III Air Conditioner
CAN R12 BE ADDED TO AN AC HOME UNIT USING R22.UNIT IS RUNNING BUT NOT COOLING
No, R12 and R22 are not compatible freons. You need to recharge with R22.
Jun 30, 2009 | Whirlwind FH-778 Air Conditioner
Looking for air recharge point
It is off the reciever/dryer. It has attachment that looks like tire valve
Jun 27, 2009 | 1996 Ford Crown Victoria
How to insert oil in outdoor of split type airconditioner
You shouldn't have to add oil. The little bit that leaks out with refrigerant isn't significant. I would be more concerned about the leak itself. Has it been located and fixed. If not it will no doubt leak out again. Also do you know how much refrigerant to put in the system? Have you vacuumed the air/moisture from the system etc. Is the system totally flat or is there still some refrigerant in it? Let me know so I can advise you correctly.
Feb 23, 2009 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
8,917 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
