Question about Pioneer TS-W307D4 Car Subwoofer
Wiring up tsw307d4 SUB
Hi.
I have a tsw307d4 pioneer subwoofa in a box which is run by a pioneer Class D Mono Amplifier (GM-D7400M). The wiring has come out of the back of the subwoofa and i dont no where it goes back in to. The sub has 2 lots of + and - outputs and i wasnt sure which ones to wire the amp back up to. Thanks.
5 Suggested Answers
Duncan
  • 218 Answers
SOURCE: 2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Posted on Mar 27, 2008
  • 4 Answers
SOURCE: how do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Posted on Mar 10, 2009
  • 65 Answers
SOURCE: i have the pioneer sub and a sony 600watt 4
it has a detector that kicks in it will usually shut off your amp and it keeps you from blowing your amp the speaker may have to much power and amp may not push it it will start to protect itself
Posted on Jun 07, 2009
  • 34 Answers
SOURCE: Hi,I like to wire up my sub-box to a 10
12 or 13. make sure toy have a fuseable link for your amp
Posted on Jan 24, 2010
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
W__How do i wire two pioneer GM-D9500F amps i only have two rca outputs on head unit one sub output that is being used with a D class mono amp for sub the other rca to one pioneer GM-D9500F amp but i have...
Hi, you can split the preamp RCAs with Ys available everywhere. The amp input impedance shouldn't cause much load on the head unit. Let us know if you have more questions, and thanks for using FixYa.
Jan 18, 2011 | Car Audio & Video
Have hooked up al conections properly acording to diagams but amp will not pwer up. tested wire conections and i am getting juice to the amp but still no responce fuse are good amp is brand new out the box...
If this is new out of box make sure you have 12volts to the amp turn on wire. You should have constant 12volt + to the battery terminal 12volt- to the ground and 12volt + from the head unit (radio) to the amp The turn on wire on most car stereos is a thin blue wire. run this wire to the amp's terminal and when you turn on the radio the amp should turn on.
Sep 29, 2010 | Pioneer GM-D7400M Car Audio Amplifier
How to install car stereo with an amplifier and equalizer
power wire from batt fused to positive on amp .earth wire eg - to bare metal in car with bolt or screw. remote wire from amp to remote wire on back of head unit mostly blue wire it tells amp when to turn on then you need a set of rca cables to send sound from head unit to amp they go in subout if you wanna use sub or rear or front out for full sound best thing is to buy amp kit cheaper most the time and all you need there hope this helps
Oct 23, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Amp connection to pioneer tsw307d4
First of all check impedence of the subwoofer and how many voice coils it is. Go to www.the12volt.com click on subwoofer wiring diagrams then you check the load that your amp is stable at. Then wire it that way. Easiest way is to print out the diagram then take it actually out to the sub and box for reference.
May 30, 2009 | Pioneer TS-W307D4 Car Subwoofer
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Pioneer GM-D7400M Amplifier Flashing
sent it to service center because the problem is inside the amp -sometimes electronics component failed by heat or bad ventilation or poor design work
Apr 14, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Mono wiring
leave rca as it is,only speaker config is needed there should be an illustration printed beside the connectors that says bridge
Aug 08, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Pioneer TS-W307D4 Car Subwoofer Logo
301 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
