Question about HP LaserJet 1022 Printer
Printer Not Woking In Network
Just set up a new Lenovo computer (WinXP) and had to re-share a HP Laserjet 1022n printer. Now when I try to print to the shared printer from another computer it will not print my document. I can only get it to print a test page so I know it's communicating with the printer. I have tried to print from Word, email, nothing else prints. No error messages just nothing comes out of the printer and the job is not sitting in the print que. I have deleted the printer and have reconnected to it through our network and I am sure that print sharing is on and the printer is shared. I have this one printer shared out to two other computers and it's happening on both so I am overlooking something. Help! all remote systems print on the network printer, but the local machine just sends out blank pages, tried on word and other programs
  • 477 Answers
1. check that not any firewall or antivirus software blocking your printer.
2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
Posted on Jul 03, 2009
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Hp laserJet 1022n printing multiple copies when copies are set to 1
Had this same problem found a working solution here http://www.tomshardware.com/forum/59912-3-1022n-printer-stop-printing.
Just disable bidirectional support in the printer properties worked for me
Jan 06, 2012 | HP LaserJet 1022n Printer
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
How to add NIC in HP color laserjet CP1215 Printer?
If this model HP does not have an expansion slot for a HP Jetdirect Print server, then to use this printer on your network you have two options.
1. Connect the printer to a desktop computer on your network and set it uo as a shared printer. This means this computer and printer needs to be powered up for the other computer on your network to print to the shared printer.
2. Connect the printer to a print server that is connected to your network.
Nov 24, 2010 | HP LaserJet P2015 Printer
Connect Ubuntu box to HP LaserJet 4000 (printer #2 - LPT2)through Hawking print server model HPS12U (internal address 192.168.1.4) Same box (and other winxp pro boxes) connect and print fine thru...
Go to System > Hardware > Printers.
Then click on Server from the Menu, and then select Settings. Check boxes:
  1. Publish shared printers connected to this system
  2. Allow printing from internet
Click OK, then click Refresh.
You can click New to add the printer, it will search and then you select Network Printer, and find a network printer.
Feb 15, 2010 | Canonical Ltd. Ubuntu
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
My shared printer will only print a test page and nothing else!
Hi phall124
Have you made the new connected printer on 2 other PC's the default printer. Try selecting the printer in word by not just clicking on printer icon but using the following:
1.File
2.Print
3.Select printer from drop down box
4.Print
Regards
Go-Tech
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Laserjet 3050, 2605dn, 1022n
One time un reinstall the all printer drivers Before u go to C:\WINDOWS\system32\spool\drivers\w32x86.then delete all folders and files
Apr 08, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 1022 Printer Logo
263 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
