Home | Canon | PIXMA MP160 All-In-One InkJet Printer | Ive been trying to hel...
Canon PIXMA  MP160 All-In-One InkJet Printer
Problem for Canon PIXMA MP160 All-In-One InkJet Printer
Ive been trying to help a neighbor install his
By meqmb2 on Jul 03, 2009
Ive been trying to help a neighbor install his canon mp160. I used the install disk and it says that there is a connection problem and that the installation failed. The printer shows up on the computer when turned on, but with bubble stating the same installation failure. I have had the cord replaced and its still a problem. Any ideas about what the problem could be? Thanks
Comments:
Jul 03, 2009
- I'm sorry I forgot to add the important info. He is using Windows XP. I installed it twice, once connecting the usb before and then after. The disk said it was good for XP, but I downloaded and installed the XP drivers to see if that was the problem and still no change.
Sponsored Links
Best Solution
posted on Jul 03, 2009
Helpful)
wayneard
Rank: Guru  Canon Expert Computer Hardware  Expert
Rating: 91%, 672 votes
Couple things:
1) When are you connecting the USB cable? Before or after installing the software?
2) What operating system are you using? Does the disk have the correct software for that OS?
Comments:
Jul 03, 2009
- I meant to post a clarification request instead of a solution, but since I did, I will say in addition to the above, the setup shows that this printer should be turned OFF and the USB cable DISCONNECTED when you install the software. When the software prompts connect the USB cable and turn the printer ON.
The support shows the same driver for Vista, XP, and Win 2000 so that should not be a problem.
However, if the computer is a 64-bit system, the driver would be different. Do yo know how to check for this?
Finally, antivirus programs and firewalls can also prevent successful installs. Sometimes you need to disable these, do the install, and then re-enable them.
Hope something helps here. Thanks for using Fixya.
Wayne
Jul 03, 2009
- Make sure you uninstall any software and remove the printer using Control Panel before attempting another install.
Jul 03, 2009
- To check for 64-bit, right click on My Computer icon and then select Properties. In the system window it should say 64-bit somewhere if it is. If it doesn't say you can assume it is a 32-bit system.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 05, 2009
Not Rated)
amin26
Rank: Master  Computer Hardware  Expert
Rating: 0%, 0 votes
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq6
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP160 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP160 All-In-One
Do you recommend Canon PIXMA MP160 All-In-One InkJet Printer?
Answer
Answer
i have placed new cartiredges in my printer after giving one print out it shows error ink observer... (More)
Answer
Hi, I cannot scan with my canon MP160, when I am trying to this the error is coming up with number... (More)
Answer
My printer is feeding the paper through slightly crooked, sometimes grabbing 2 sheets at... (More)
Answer
printer works, but will not scan. MP Navigator Icon has disappeared, and I cannot locate any... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA MP160 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 418
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
