Question about Kenmore 15358
Thread goes off screw when i start sewing
When i start to sew, the thread goes crazy. it won't stay in place...it's ridiculous. it literally flies off the screw. have a kenmore machine which is 5 or 6 years old and no idea where the manual is.
am i threading the machine incorrectly?
(i'm very new at this)
    President:
  • 1,952 Answers
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Kenmore Owners Manual
Posted on Jul 03, 2009
WHY IS MY THREAD WRAPPING AROUND THE BOBBING IN THE SHUTTLE WHEN I PRESS START
THE BOBBIN HAS ONE METAL PART ON TOP AND ANOTHER PART THAT KEEPS THE BOBBIN FROM MOVING FORWARD. TURN YOUR HAND WHEEL AND WATCH WHICH PLACE DOES THE THREAD GET STUCK. IF IT IS THE ONE ON TOP THEN IT WILL NEED TO BE RAISED SLIGHTLY BY MAKING A PULL WITH NEEDLE NOSE PLIERS. (VERY SLIGHT) IF IT GOES UNDER IT BUT STOPS AT THE AREA WHERE THE LITTLE INDENTATION IS THEN YOU WILL NEED TO LOOSEN ONE OF THE SCREWS AND SLIGHTLY TO ALLOW THE THREAD TO PASS BY. THE THREAD HAS GOT TO PASS THESE AREAS OR YOU WILL NOT SEW.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
Thread does not wound evenly on spool. Therefore when sewing it goes crazy with the thread on underside of fabric and then jams. What can I do to keep thread going on the spool evenly?
Your talking about the bobbin? If so your not threading it properly to feed the bobbin while winding. Sounds like you don't have the proper tension from proper threading.
Oct 28, 2014 | Simplicity Liberty SA1600 Mechanical...
Needle won"t stay threaded
that use to happen to me on my sewing machines, I would rethread the machine to make sure the thread is not caught on anything like the thread spool, or around anyone of the thread guides
also for both top & bottom threads, I keep a thread tail of 3 to 6 inches & before I start sewing I pull the thread behind the needle to the back of the machine & the I put the fabric under the foot & start sewing & now I don't have that problem anymore
Aug 24, 2011 | Singer 3116 Simple
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
HI I HAVE A BROTHER XL-5011, the clamp that holds needle in place fell off whilst sewing now it won;t stay on thnxs
needs a new needle clamp screw & possibly the needle clamp too
try sewingpartsonline.com
Jan 11, 2011 | Brother Sewing Machines
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Jun 27, 2009 | Bernina Bernette 75
Brother 270D Sewing Machine - Bobbin Winder
The screw threads might, possibly, have been stripped. If so, wrap some plumbers Teflon tape around the screw threads. That should help sock the screw in snugly. The tape is dirt cheap and goes a long, long way.
Nov 29, 2017 | Brother Sewing Machines
Do I need a new part?
The thread can strip either on the the screw or the bar it goes into, usually it is just the just the screw, get a new screw and put just a small drop of nail polish on the thread this will prevent it from coming loose.
Jun 07, 2008 | White Sewing Speedylock 1600 Mechanical...
Kenmore 15358 Logo
179 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
