Question about Samsung SpinPoint V40 SV6003H 60 GB Hard Drive
Hi! I have a Samsung Spinpoint SV6003H HDD that I pulled out of an old computer, put it in a drive enclosure and connected it to my computer to use as an external drive. The problem I'm having it is keeps going in and out. Power seems consistent, but my computer recognizes it one minute than it's gone the next, then back again, and so on. It stayed long enough for me to repartition and format it, so there is no data on it. Windows Disk Management shows healthy when it recognizes it. Might it be those goofy jumpers? i have it set to Master according to the manual: http://downloadcenter.samsung.com/content/UM/200310/20031006144428687_InstallGuide_ENGLISH.pdf using pins AB&FH... any ideas what could be wrong? Thanks!
    Habit-Forming:
  • 64 Answers
My experience has shown that there is a GREAT difference between different USB cables. I have had some which did not seem to transfer the power efficiently to the device. I've had others which would not make a connection to my computer at all.
I almost threw away a number of very expensive LiON batteries for my Sony camera because the USB cord I was using to charge the batteries in the camera was not working. Then I was surprised when a shorter USB cable from a cheap device worked just fine with my Sony camera, and I was able to charge all my batteries.
I have accumulated a number of different USB cords. And I try them all until I've run out of cords to try, or I find one that works.
Posted on Mar 25, 2017
Falling Down
  • 67 Answers
SOURCE: Samsung 160gig hard drive printed circuit board
try ebay with the same model number. You can transfer the circuit boards, retrieve the data, then you have a spare backup. Otherwise you can try to identify the component and check if digikey or mouser has a replacement. Sometimes if you're lucky the component is a bias diode that is designed to burn out with reversed power. Sometimes the visible damage may not be the only damage and other parts have fried. Touch a grounded object (like the case of your computer that's plugged in) before touching the components, and retouch it frequently, or wear static dissipative wrist strap
http://www.digikey.com/
http://www.mouser.com/index.cfm?handler=home
Posted on Nov 30, 2007
Benimur
  • 6966 Answers
SOURCE: using as startup disk
If you used Acronis, you need to clone the 30Gb and not backup. In doing so, the booting information is likewise copied to the 80Gb, whereas back up is simply copying contents (that you specified) hence will not boot and not be active.
Pls remember that by cloning, Acronis would erase the partition (and contents) of the 80Gb. At certain settings, it would also split the 80Gb into 2 partitions; 30Gb & 50Gb. Further, verify that the 80Gb is "Set Active" and partitioned as a Primary and not Logical.
As to your other concern of installing, in some instances, some not so recent motherboards' BIOS/CMOS will not recognize the 80Gb. Other than that, you were doing it correct; new 80Gb as primary/master with jumper to the pins nearest the IDE cable, any other device (CD ROM or another HD) should be set as primary/slave (SL). Additionally, pls verify that your motherboard auto-detected your new 80Gb as your primary boot media (settings in your CMOS/BIOS).
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 04, 2007
suisboy
  • 175 Answers
SOURCE: SAMSUNG IDE HDD SP0411N (40GB)
use the partion magic software may be ur disc remain unpartioned.
i recomend you to use fidsk or un partion all the disk and then re partioned may be it lost the boot sector allocation table.
Posted on Jan 06, 2008
SOURCE: jumper pin settings
Hold the samsung SP1203N hard drive in your left hand with the lable facing upwards (then power cable connectors will be on your right hand side and the IDE cable connector will be on your left ahnd side). There are two raws of jumper pins in between the above two connectors
Master - join the first two column of pins on the left with a vertical jumper
Slave - leave all pins free (without jumpers)
Cable Select - join the third column of pins from the left with a vertical jumper
job done !!
Udai De Silva
Posted on Jan 08, 2009
Crankstart
  • 696 Answers
SOURCE: remove the bad sector from samsung sp0411n
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
Posted on Jun 04, 2009
Need connector
I found this possibility
http://www.startech.com/HDD/Enclosures/18in-USB-to-Micro-SATA-Hard-Drive-Enclosure~SAT1810U2 - I am sure you can buy this in other countries, perhaps through Amazon or other retailers. I am sure there other manufacturers of similar products besides Startech.
22.April.2014
Apr 15, 2014 | Samsung SpinPoint 3600RPM 1.8" 5.0mm...
I am using this HD as an external hd. My pc is unable to read or indentify that it is connected. I have another hd that I have connected and my pc can read it. The Spinpoint is spinnning/but how can
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
Hope this helps.
Nov 24, 2012 | Samsung SpinPoint V40 SV6003H 60 GB Hard...
Dead processor. good hard drive
get external hard drive shell, place the hard drive in it, the connect via firewire or usb all your info should be intact except if its a crash
Mar 23, 2010 | IBM ThinkCentre A50 PC Desktop
Is my hard drive broken? Cant get it recognised on other PCs
I'm having a similar problem with the same Akasa integral enclosure, so far I have tried 3 different hard disks and not one of them will work properly and on two different computers.. , all of the hard disks I've tried are Samsung .. but I'm sure that makes no difference. I plan to send back the enclosure to where I bought it from and get a different one from a different manufacturer.
Dec 10, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
I want to pull info off a hard drive & put onto a disc.
If your new computer doesn't accommodate the drive then you will need a three and a half inch hard drive enclosure to put the hard dive in from the other computer.
You will have to look at the drive to work out which type enclosure you will need.
It will either be a SATA connection like this >>>>
Or a IDE/ATA connection like this >>>>
If you compare the connections on these examples you will one has plastic connections and one has brass pin connections.
As soon as you know which type of drive you have you can then proceed to purchase an enclosure.
When you have got the correct enclosure all you have to do is install the drive and connect it your new computer.
You will be able to access the drive, copy your data and use the drive as an external hard drive.
Regards.
Sep 22, 2009 | Dell Dimension E310 PC Desktop
HDD enclosure does not work
For that you need to uninstall all usb driver from device manager.
Right click on my computer icon then you see system property then go to hardware -> device manager then uninstall usb drivers 1 by 1 .
Then restart computer then all usb drivers are automatically installed.
Then connect your harddrive if still face same problem then connect your harddrive to another computer then check.
If another computer cant see your harddisk then your harddisk has hardware issue.
It need repairing .
If it is in warrenty take it to service shop they replaced it.
Aug 01, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
JUMPER SETTING
to make a HDD as slave, put off the jumper out.
for any question ask me.
Thanks for your question.
Aug 31, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
SAMSUNG SV0411N HDD SHOWN ONLY 7.85 GB
you seem to have a hidden partition Have you used FDISK ? this can be downloaded just do a search You then need to remove all partitions - you seem to have only formatted part of the drive.
Jun 02, 2007 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung SpinPoint V40 SV6003H 60 GB Hard Drive Logo
183 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
